What is the outcome of setting the 1st, 2nd ->3 shift speed at the speed I want 2nd to 3rd to shift at.
Does this mean I can just drop it into first and take off and it will automatically shift from 2nd then 3rd without me touching the shifter? (gto has n A4)
And if I have 1->2 set at 40, does that negate the above and then use the 2 -> 3 shift speed?
LABELS
Parameters Value
{D0910} WOT 1->2 Shift Speeds, Normal 35.000000 MPH
{D0911} WOT 1->2 Shift Speeds, Performance 35.000000 MPH
{D0912} WOT 1->2 Shift Speeds, Hot 35.000000 MPH
{D0913} Manual Hold Gear, 1st, 1->2 Shift Speeds 40.000000 MPH
{D0915} WOT 2->3 Shift Speeds, Normal 67.500000 MPH
{D0916} WOT 2->3 Shift Speeds, Performance 67.500000 MPH
{D0917} WOT 2->3 Shift Speeds, Hot 67.500000 MPH
{D0918} Manual Hold Gear, 1st, 2->3 Shift Speeds 85.000000 MPH
{D0919} Manual Hold Gear, 2nd, 2->3 Shift Speeds 85.000000 MPH
{D0920} WOT 3->4 Shift Speeds, Normal 119.000000 MPH
{D0921} WOT 3->4 Shift Speeds, Performance 119.000000 MPH
{D0922} WOT 3->4 Shift Speeds, Hot 119.000000 MPH
