Results 1 to 3 of 3
Thread: Help! *.pmm $ 0482
    Jan 2015
    Default Help! *.pmm $ 0482
    I keep getting the *.pmm $ 0482 as soon as I connect my v2 . this is really getting annoying every time I update it's some new issue with the software or firmware. everything is up to current specs via efilive requests . I can't seem to get rid of this error .
    I've reconfigured with the v8 :
    (program quick setup)
    version 2.07.07 date Feb 07, 2014
    firmware 2.07.82 date Apr 10, 2015
    just updated it today sat may 2015
    Quote Originally Posted by thelsxguy View Post
    so now you should see this:
    V7 build 284
    V8 build 277
    V2 firmware 2.07.82
    V2 bootblock 2.07.07
    you have to keep V7, V8, V2 firmware/bootblock, and V2 BBx config files (*.pmm etc) all sync'd up.
    Nov 2005
    Please provide a full list of your software and firmware details - stating you are up to date does not allow anyone to validate that information.
    When you update software and firmware, using V8 software click the Check firmware option and ensure your configuration files are also updated.
    You'll find instructions in the knowledgebase for upgrading bootblock, firmware and config files (*.pmm) here https://support.efilive.com/kb_artic...7243-SFGL-2949
    Cindy
  1. Replies: 9
    Last Post: June 1st, 2015, 03:12 AM
  2. error: $0482
    By x MadMAX DIESEL in forum Diesel
    Last Post: July 20th, 2013, 05:09 PM
  3. Error$0482
    By J.Abbott in forum General
    Last Post: May 30th, 2013, 04:51 AM
  4. lly.pmm file
    By electricblue in forum Duramax LLY
    Last Post: October 2nd, 2011, 01:33 AM
  5. PMM file question
    By 860 in forum FlashScan V2
    Last Post: March 24th, 2009, 12:57 PM
