Results 1 to 7 of 7
Thread: COS5 Questions
    Mar 2015
    Default COS5 Flashed and now PCM Locked
    Howdy everyone.
    I am not new to the tuning world, just new to the COS setups. I have a 12212156 os for a LS1B controller and did the full flash of the 02020005 os and then cal flashed with the stock cal files. Went to read the COS5 with the stock cal flash to edit and now the controller is locked. I cant do anything that will allow me to read or change the file, cant even full flash stock file. What happened? Please Help Joecar!!! I know the master brains here can help.
    Dark Horse Customs
    Was it a 512KB LS1B PCM...?
    ( i.e. not a 768 KB or 1 MB PCM )
    Is it in the vehicle or on the bench...?
    Mar 2015
    It was a 512kb and the ecm was in the vehicle. This is 78 trans am that has this transplanted in. The ecm gets power from an auxiallary switch panel. I feel there is no electrical interference that could be causing issues.
    Which V7 and V8 software build versions...?
    Mar 2015
    software versions 7.5.7(build 284) and 8.2.2.277
    See Issue #6 here
    https://forum.efilive.com/showthread...Public-Release
    An update is planned for later today that will allow you to restore the lock on your LS1 controller so it works normally again.
    Until then to read/flash the controller, you'll need to select the "Try Alt Keys" and "Assume Lock May be Faulty" options.
    Mar 2015
    Thank you Paul. Your idea worked. Cant wait for the update, still haven't seen it. EFI Live Rocks!!!
  1. More COS5 questions
    By FreshDA9 in forum Gen III V8 Specific
    Last Post: July 3rd, 2013, 03:04 PM
  2. COS5 Turbo Questions
    By ferocity02 in forum Custom Operating Systems
    Last Post: June 7th, 2013, 06:02 AM
  3. COS5 questions
    By JWolfe75 in forum Custom Operating Systems
    Last Post: August 1st, 2011, 01:59 AM
  4. My first 99-02 cos5 2 bar attempt... some problems and questions
    By Johnyhotrod in forum Gen III V8 Specific
    Last Post: May 16th, 2009, 02:56 PM
  5. Just installed COS5 - Questions
    By jermstyle in forum Custom Operating Systems
    Last Post: January 1st, 2009, 12:06 AM
