I have a 67 Nova that has a 01 vette engine transplanted in it. I can't seem to make it idle. I flashed OS 12584929 and made mods to VATS, ECT, and removed the rear O2 references. It only starts with by applying throttle of 10% or more. With throttle applied it runs at 1000-1200rpm, spark 30 degrees, trim -3% to 0%, injector duty cycle of 3 to 4%. If the idle falls below about 950 then it dies. I even set the idle parameters at 1000rpm and it won't idle. It must have something to do with the vette throttle system. Any advice...
