Results 1 to 5 of 5
Thread: lm7 speed density tuning
    Jun 2015
    Default lm7 speed density tuning
    looking for help trying to figure out speed density tuning it is on cos 3 and maf should be completely disabled. Would like to find out what tables all need to be altered. It is going to be boosted within a week and would like to try to get this crossed of my list sooner then later. Thank you to everyone in advance for the help. The cos 3 for my truck is below and the one I was trying to learn with that I would assume it is wrong.
    Attachment 18485
    Attachment 18486
    Jun 2015
    if anyone were to have a boosted 5.3 tune with a speed density tune that would also be greatly appreciated im running cos 3150003
    Aug 2015
    any luck?? Im also building a boosted 5.3 and starting to look into tuning it. Avid duramax tuner but editing tables that don't exist is hard.
    If you use a 1MB PCM, make sure it's an 05 or older OS. EFILive doesnt have a COS for 06-07 OS'. Otherwise shouldn't be an issue, go SD and dial it in.
    Make sure you get a MAF DTC immediately on startup (this verifies that MAF is disabled/ignored), see C2901,3,4,6 and C6001.
    You want to disable CL/LTFT/STFT and OL/STFT, see B3801, B4205, B4206... and make sure B3647,9 contain no stoich cells.
    Make sure fueling errors on the rich side, see B3647,9 and B3618 (make sure PE enables, see B3616, B3613)... bump up VE B0101.
    Note: make sure B3647 makes sense (and doesn't just contain remnant data from B3605).
    You then edit VE table B0101 and Boost VE table A0009... and when done you also edit Cranking VE B0102.
    You will need to edit A0008 for cold startup.
    You will edit Boost Timing table A0010.
    Also, before proceeding you will need to fix any out-of-range value in any table in the A segment, for example:
    Out of Range calibration summary: 06:21:46 pm, Tuesday Feb 07, 2017
    EFILive Custom Calibrations
    {A0001} Forced Octane Scaler Percentage, was out of range when loaded.
    {A0002} Octane Scaler Limiter, was out of range when loaded.
    {A0004} MAP Disable TPS VE Table, was out of range when loaded.
    {A0005} RPM Disable TPS VE Table, was out of range when loaded.
    {A0006} TPS Disable TPS VE Table, was out of range when loaded.
    {A0017} N20 Monitor VE Multiplier Table RPM Enable, was out of range when loaded.
    {A0018} N20 Monitor VE Multiplier Table MAP Enable, was out of range when loaded.
    {A0007} TPS VE Table, contained one or more out of range values when loaded.
    {A0015} N20 Monitor VE Multiplier, contained one or more out of range values when loaded.
    {A0016} N20 Monitor Timing Table, contained one or more out of range values when loaded.
    ( including A00012,13 if your COS has them )
    Note: in presence of MAF DTC, the COS's retain HO/LO adaptive spark.
    Note: the 105 kPa columns of B0101 and A0009 should be identical.
  1. Speed Density Tuning, Trans now shifting harsh!
    By hotrod in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 21st, 2014, 12:29 PM
  2. Tuning LS1 Superchared 02 TA with speed density and o2
    By RamAir in forum Gen III V8 Specific
    Last Post: October 30th, 2012, 02:34 PM
  3. Tuning Speed Density with Auto VE
    By supercharged88 in forum Gen III V8 Specific
    Last Post: September 9th, 2012, 07:14 AM
  4. speed density
    Last Post: January 14th, 2006, 06:13 PM
  5. Speed density
    By Drake in forum Tutorials
    Last Post: February 22nd, 2005, 03:01 PM
