Results 1 to 10 of 12
Thread: COS Tutorial question...
    Member overS10ded's Avatar
    Mar 2009
    Default COS Tutorial question...
    I am having a hard time with page 10 of the Custom OS Upgrade Tutorial where as the MAP climbs, the lambda is leaned???? Shouldn't it be richened instead?? Also in the AutoVE tutorial as well, lambda leaner than 1 (14.68AFR) are indicated using as lean as 1.17 in the 100 kpa column....that just doesn't seem correct. What am I missing???
    The AutoVE tutorial page 7 says that if my calibration is displayed in lambda, fill in as shown, and if in AFR fill in accordingly however the lambda once again is leaned in higher MAP pressures while the AFR calibrations are richened in the higher MAP pressures.
    Good times!
    Bruce
    Brucemobile: '91 S10 Blazer 4dr, 4x4 - '96 4.3 Vortec V6-stock, '0411 PCM conversion, marine manifold conversion, 44# Deka injectors, intercooled Procharger P1SC w/3.2 pulley, Headman long tube headers - 3" single exhaust, custom 700r4, 2500 stall w/lockup, 2002 S10 Blazer suspension and 4 wheel disc brakes, coil over front suspension conversion-torsion bar delete, zexel torsen posi 3.42 w/ 245/45r17's. EFILive tuning.
    Mar 2009
    ...OK EQ ratio ... got it! Does it matter which value; Lambda, EQ ratio, AFR, is used in the tables such as B3647?
    Good times!
    Bruce
    Hi Bruce,
    I would rather you used EQR for commanded fuel and Lambda for wideband measurement...
    this "convention" avoids confusion during discussions, and it makes the BEN pid simpler (BEN = commanded_EQR * wideband_Lambda)
    (simpler as in you don't have to remember which is numerator and which is denominator).
    Mar 2009
    Thank's Joe, I appreciate your time and explanation. The more I learn, the luckier I realize I am for not melting my engine w/ ignorant/lazy tuning, and how forgiving the COS has been set up by Efilive for sloths like me. I've taken the winter to read ALL EFILive material and purchased/read (2) ebooks; "Engine Management Advanced Tuning" and "How to Use and Upgrade to GM Gen III Powertrain Controller" which helped me also incorporate my dual fans through the '411 and got rid of the thermostats with the pigtail senders stuck into the radiator. Tons of great info!!
    Good times!
    Bruce
    Hey Bruce,
    This thread contains more info (see posts #4, #29, #38): Summary-Notes
    Mar 2009
    Joe, on post #38 from your Summary-Notes thread, in regards to logging for AutoVE you indicate modifying the BEN pid, evidently this is still recommended (hasn't been included in updates)? I'm working with AutoVE logging now. I don't see how to modify the pid equation yet to modify the BEN to "WO2BEN = {GM.EQIVRATIO}*{CALC.AFR_LC11}/14.7" equation yet...
    Good times!
    Bruce
    Post your V7 calc_pids.txt file here, I'll edit it.
    Do you have FlashScan V1 or V2...?
    You have an LC-1...?
    Mar 2009
    Joe, I have the V1 and LM-1. I think I have attached the file you asked for, from User Config? Thanks for your help!
    Good times!
    Bruce
    calc_pids.txt
    Bruce,
    Is your LM-1 programmed with the default LM-1 AFR-to-V curve, or is it programmed with the one from the LC-1...?
    Mar 2009
    I'm sure it would be the default curve as I have never re-programmed and didn't know I could until your last post! I will stick with the LM-1 default for now.
    Good times!
    Bruce
  1. "Going Mafless" in COS Tutorial?
    By DrX in forum Custom Operating Systems
    Last Post: August 27th, 2011, 12:11 PM
  2. quick question about the CALC.VE tutorial
    By BlackGMC in forum Gen III V8 Specific
    Last Post: September 30th, 2010, 04:23 PM
  3. Question on Tuning with AutoVE tutorial
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 1st, 2009, 03:35 AM
  4. Hey Ross! COS Tutorial
    By TAQuickness in forum Tutorials
    Last Post: April 29th, 2006, 04:27 PM
  5. BEN_LC12 and AutoVE tutorial Question
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2006, 10:07 AM
