Results 1 to 5 of 5
Thread: FlashScan Screen blacks out
    Dec 2007
    Default FlashScan Screen blacks out
    Something is going on with my Flashscan where it randomly blacks out the screen. The best I can tell it's just the LCD backlight because you can almost see the characters at certain angles and the LED's don't change. Also if I touch the surface in the right place or tweak the Flashscan in my hand it will illuminate, but pressing a button often makes it go black again. When it recovers it's still on the same screen so I think it's just a faulty connection somewhere.
    I have had it for years so it's not under warranty, but I'm wondering if this is an easy fix assuming I open it up.
    Is there a ribbon cable with the backlight power supply line going to the LCD?
    Can the Flashscan operate with reduced power, just not illuminate the LCD?
    I also have a broken locking tab on my RJ45 connector so I wonder if it's not always getting a solid 12v connection.
    Suggestions, help would be appreciated.
    I'm electronically capable, but I REALLY don't want to screw it up just poking around at stuff.
    Thanks,
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    Where are you located...?
    Dec 2007
    Antelope Valley Ca. about 30 miles north of SoCal Diesel in Southern California who I purchased it from originally.
    -Adam Chant
    Tune it or lose it!
    EFILive Tuned
    SoCal Diesel would be whom you contact to get it repaired.
    Dec 2007
    OK, Thank you. I need to get a new OBD-II cable for it anyhow so I will contact them.
    -Adam Chant
    Tune it or lose it!
    EFILive Tuned
  1. Flashscan screen issue
    By LMMPerrona in forum FlashScan V2
    Last Post: January 20th, 2015, 10:30 PM
  2. Flashscan V2 Fuzzy Screen
    By lmn8636 in forum FlashScan V2
    Last Post: August 9th, 2013, 02:02 PM
  3. V2 Screen Contrast How???
    By JR-CRUZN-C5 in forum FlashScan V2
    Last Post: April 26th, 2008, 08:27 PM
