I was maxing out my old faithful White Giant 36#ers and ended up buying Siemans Deka 44# injectors and the "efilive freindly" specs aren't working for my 39# rail pressure because they are for 4bar cars (I was told this buy the salesman-jon) and their advice was to "rape the injectors" (the specs I presume). So the 36's always held 14.6 on the LM-1 in my console but after sticking the "company's" numbers in the tune it was pig rich with the new injectors idling at 12.5afr. I started deleting 10% at a time from b3701 and finally at 4 x 10% it was too lean at 15.1afr. I was expecting less problems from a injector swap...right. So I'm chasing this like crazy now and I'm hoping someone might have some good numbers for me. Here is the spread sheet they sent me. I found some other info that had quite different numbers than these so looking for good info. Thanks and Good times! Bruce
0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
Grams / Sec 5.477 5.523 5.568 5.613 5.657 5.701 5.745 5.788 5.831 5.874 5.916 5.958 6.000 6.042 6.083 6.124 6.165
LB/hr 43.471 43.831 44.189 44.544 44.897 45.246 45.593 45.937 46.279 46.618 46.954 47.289 47.621 47.950 48.278 48.603 48.926
* If FPR manifold referenced
Injector Voltage Correction - B4002
4.5 5 5.5 6 6.5 7 7.5 8 8.5 9 9.5 10 10.5 11 11.5 12 12.5 13 13.5 14 14.5 15 15.5 16 16.5 17
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
Min Puls & B4004 Def Pulse - B4003
0 400 800 1200 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800 7200 7600 8000
0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805 0.805
Short Pulse Limit
2.5 msec
Small Pulse - B4005
0 0.061 0.122 0.182 0.243 0.304 0.365 0.426 0.486 0.547 0.608 0.669 0.729 0.79 0.851 0.912 0.973 1.033 1.094 1.155 1.216 1.277 1.337 1.398 1.459 1.52
0.472905 0.465578 0.450586 0.429192 0.40405 0.377697 0.351788 0.327369 0.304529 0.28281 0.262211 0.243198 0.225743 0.209166 0.193101 0.177656 0.163022 0.148936 0.135842 0.125256 0.117529 0.111434 0.105897 0.100449 0.095032 0.089652
Offset - B3701
Manifold Vacuum kPa {link: GM.MANVAC} 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
4.5 6.219538 6.237269 6.263569 6.290164 6.322375 6.361973 6.40423 6.446488 6.486381 6.520956 6.553166 6.585672 6.62261 6.667823 6.71274 6.75677 6.792527
5 6.119952 6.137683 6.16395 6.19048 6.222592 6.262124 6.304349 6.346606 6.386533 6.421173 6.453481 6.48602 6.522958 6.568138 6.613088 6.657151 6.692941
5.5 5.308457 5.326122 5.352192 5.377835 5.408929 5.447444 5.489242 5.531105 5.570703 5.605671 5.638374 5.671208 5.707195 5.751915 5.796438 5.840665 5.876192
6 3.382998 3.399777 3.424665 3.44778 3.473456 3.508523 3.546775 3.585125 3.621341 3.65365 3.686451 3.71656 3.749066 3.787416 3.830232 3.870125 3.902401
6.5 2.196701 2.211181 2.230127 2.24917 2.26782 2.294383 2.323277 2.349577 2.377125 2.401521 2.423848 2.446077 2.46929 2.497429 2.526455 2.552065 2.572685
7 1.655956 1.66538 1.678316 1.691187 1.705503 1.723496 1.73965 1.755805 1.773929 1.789099 1.802889 1.816548 1.830929 1.845442 1.859922 1.872629 1.8789
7.5 1.343802 1.351584 1.362058 1.372959 1.384549 1.396238 1.407303 1.418303 1.429237 1.439973 1.449988 1.459936 1.469918 1.47921 1.485022 1.492442 1.495266
8 1.117509 1.124405 1.133828 1.143645 1.154087 1.163904 1.172966 1.179238 1.18807 1.196081 1.200711 1.208526 1.216406 1.221495 1.227931 1.231378 1.235876
8.5 0.951336 0.95741 0.963189 0.971398 0.980821 0.989653 0.995104 1.00305 1.01024 1.013786 1.015953 1.018646 1.024195 1.027675 1.033224 1.036475 1.038215
9 0.815238 0.820525 0.82476 0.831294 0.836416 0.844264 0.851553 0.856577 0.862946 0.865573 0.866197 0.867248 0.869086 0.871647 0.87434 0.879593 0.881301
9.5 0.70682 0.711877 0.715193 0.718017 0.723631 0.727834 0.734302 0.739162 0.744875 0.74806 0.749209 0.750128 0.751212 0.755743 0.75837 0.760898 0.765199
10 0.618989 0.620631 0.625227 0.627788 0.62989 0.633206 0.638854 0.642991 0.649262 0.652578 0.657109 0.658062 0.659047 0.661411 0.666664 0.669159 0.670177
10.5 0.551646 0.552565 0.554371 0.556867 0.561562 0.564222 0.567045 0.573185 0.576666 0.582642 0.585038 0.585958 0.586253 0.587961 0.593181 0.595677 0.596695
11 0.489294 0.490246 0.492085 0.497306 0.499965 0.50269 0.508732 0.511523 0.514773 0.51937 0.521012 0.521242 0.521373 0.522358 0.524821 0.530041 0.531716
11.5 0.427402 0.429043 0.434231 0.436858 0.439583 0.445658 0.449039 0.454359 0.456132 0.45715 0.457938 0.458036 0.458102 0.458463 0.460893 0.466146 0.468444
12 0.371518 0.376542 0.379201 0.381894 0.387311 0.390726 0.396735 0.398606 0.399558 0.399723 0.399788 0.399821 0.399887 0.400806 0.40317 0.408325 0.409967
12.5 0.329819 0.332314 0.338356 0.341114 0.343839 0.349815 0.352409 0.354083 0.35428 0.354313 0.354313 0.354313 0.354412 0.355298 0.359632 0.361307 0.362193
13 0.290122 0.296098 0.300301 0.305817 0.308444 0.310972 0.315437 0.316357 0.316488 0.316488 0.316488 0.316488 0.316554 0.317309 0.318163 0.318984 0.319115
13.5 0.250032 0.260013 0.26553 0.268353 0.272852 0.274526 0.275478 0.276233 0.276299 0.276299 0.276299 0.276299 0.276332 0.276398 0.276496 0.276562 0.276595
14 0.212535 0.22255 0.230134 0.232236 0.233254 0.234074 0.234239 0.234304 0.234337 0.234337 0.234337 0.234337 0.234337 0.234337 0.234337 0.234337 0.234337
14.5 0.181737 0.188337 0.192474 0.194378 0.194641 0.194706 0.194739 0.194739 0.194739 0.194739 0.194739 0.194739 0.194739 0.194739 0.194739 0.194739 0.194739
15 0.15107 0.154386 0.160592 0.162529 0.162792 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824 0.162824
15.5 0.120567 0.127265 0.134817 0.137542 0.138494 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593 0.138593
16 0.092855 0.103033 0.109403 0.115116 0.116824 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021 0.117021
16.5 0.06905 0.079327 0.086419 0.092855 0.095219 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449 0.095449
17 0.04669 0.054275 0.063436 0.069838 0.071611 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808 0.071808
17.5 0.025217 0.032703 0.041141 0.044654 0.045705 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804 0.045804
18 0.009752 0.017172 0.024921 0.027679 0.02804 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073 0.028073
