Thanks. Looks like I need to plan some time to play around with the apply/release.
I was able to make some changes to the apply/release tables and noticed a huge difference. Basically raised each by 10%. I am going to tweak them a little more to get it even better.
I know to make sure not to exceed the apply speed with the release speed, but is there a minimum gap I should maintain? for instance say if my apply for 3rd gear is 35 and my release is 31, can I bring that gap closer? TIA.
You need some hysteresis to avoid oscillating between release and apply.
