Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: Procharged C7 closes throttle @ WOT !!! need help
    Lifetime Member wesam's Avatar
    May 2010
    Default Procharged C7 closes throttle @ WOT !!! need help
    I need help with C7 with D1 Procharger Auto tranny
    The car will not allow to open the throttle 100% while WOT
    I start by adding 50% to B8802,B8803,B8804 and B7717
    then adding 20% until i maxed out those tables but the throttle still not open 100%
    Any help will be appreciated
    EFILive Tuner
    May 2010
    EFILive Tuner
    Apr 2015
    I had this problem years back on a Lamborghini using stock electronic throttle bodies. The boost pressure was overcoming the throttles and putting them in a failsafe slamming them shut at 7200 RPM (redline was 8300). Had to change both TB's to Motec to solve it. Not certain if this is related but might be worth checking.
    May 2010
    To the top
    EFILive Tuner
    What is it going to? If it is 84% on the scanner then that is fully open in GM world.
    May 2010
    I'm loging ETCTP so it should show 100%
    Its showing between 50-60% !!!
    EFILive Tuner
    May 2010
    To the top !!!
    EFILive Tuner
    Jul 2003
    Is it an Automatic?
    May 2010
    Yes Auto !!
    EFILive Tuner
    Jul 2003
    how much power did it put down?
  1. Throttle closes momentarily??
    By DrX in forum Gen III V8 Specific
    Last Post: May 30th, 2015, 09:58 AM
  2. Which PID with E38 ecm to show 100% throttle position at WOT
    By 67SS509 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2013, 01:52 PM
  3. Throttle body closes after fast shift to third and maybe fourth. C6Z
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: May 3rd, 2011, 05:05 PM
  4. Procharged C-6
    By FFP in forum Gen IV V8 Specific
    Last Post: April 27th, 2007, 03:13 PM
  5. LTFT desired values for idle, light throttle, WOT
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2006, 12:55 PM
