Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Thread: Procharged C7 closes throttle @ WOT !!! need help
  1. #11
    Lifetime Member wesam's Avatar
    May 2010
    With 70% throttle ppen nearly 540 whp
    EFILive Tuner
  2. #12
    Jul 2003
    Not bad....
  3. #13
    May 2010
    What do you think the problem is ?
    EFILive Tuner
  4. #14
    Lifetime Member MN C5's Avatar
    Mar 2005
    Quote Originally Posted by wesam View Post
    I had the same issue on my Denali. I resolved it but I don't recall the tables I used to do it. I'll try and get a look in the next day or two and PM you.
  5. #15
    Jul 2003
    His problem was fixed a while ago!!
  6. #16
    Apr 2012
    Having the same problem on an engine dyno...what was the resolve?
  7. #17
    Apr 2016
    Any word on the solution?
  8. #18
    Try to set the rev limiter a little lower.
  9. #19
    Jan 2012
    Any updates on this ?
  10. #20
    Senior Member RandyWS6's Avatar
    Jan 2005
    I had the same problem with my C7 with a A&A supercharger, the BARO codes that you have and had to cut the wires that goes to the MassAir for the BARO and had to wire a plug that fit my factory MAP sensor, that i had to replaced with a 2.5 bar map on the intake for boost, and tie wrap it under the hood in free air and now the code are gone for good been 2 years now. If you need to know witch wire to cut i can take some pics tomorrow and send them to you or post them .
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
  1. Throttle closes momentarily??
    By DrX in forum Gen III V8 Specific
    Last Post: May 30th, 2015, 09:58 AM
  2. Which PID with E38 ecm to show 100% throttle position at WOT
    By 67SS509 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2013, 01:52 PM
  3. Throttle body closes after fast shift to third and maybe fourth. C6Z
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: May 3rd, 2011, 05:05 PM
  4. Procharged C-6
    By FFP in forum Gen IV V8 Specific
    Last Post: April 27th, 2007, 03:13 PM
  5. LTFT desired values for idle, light throttle, WOT
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2006, 12:55 PM
