Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 65
Thread: Procharged C7 closes throttle @ WOT !!! need help
  1. #21
    Oct 2015
    Whatever became of this?
    I am having the same issue on a dyno with a 2014 Corvette Z51 Auto.
    The throttle closes to 58% during a WOT run.
    A&A kit. 8 pounds of boost. ZR1 MAP sensor.
  2. #22
    Please post your tune file, and a log file.
  3. #23
  4. #24
    Oct 2015
    I hope those made it in
  5. #25
    Try this: in B5201 set Park and Neutral to 6600 rpm.
  6. #26
    Also in B5212 set the 4000 values to 6600 just in case.
    Are you getting any DTC's...?
    Was this car previously NA and now it has an SC...?
    Also look at C1801, C1802, C1803, C1804.
  7. #27
    Oct 2015
    I have not been getting any DTC'S with the car.
    Yes, it was an N/A car! The customer installed an A&A kit himself.
    I will play with those tables this morning and see what it does.
  8. #28
    Oct 2015
    The car set a DTC
    P2229
    Baro sensor circuit high.
    First time it popped it.
  9. #29
    Does he have the right MAP sensor...?
  10. #30
    Oct 2015
    (E-92) 2014 Rob Anthony Vette Z51 Auto 6.2L (12660065)-14_0000 - J.ctz
    WOT 2.efi
    I made the adjustments and the throttle is still closing. Crazy! I've never seen this before.
    I'm going to upload the trans file too. Maybe the trans is messing with the ECU on this one? (T43) Rob Anthony 2014 Vette Z51 Auto (24270599)-Base_0000.ctz
  1. Throttle closes momentarily??
    By DrX in forum Gen III V8 Specific
    Last Post: May 30th, 2015, 09:58 AM
  2. Which PID with E38 ecm to show 100% throttle position at WOT
    By 67SS509 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2013, 01:52 PM
  3. Throttle body closes after fast shift to third and maybe fourth. C6Z
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: May 3rd, 2011, 05:05 PM
  4. Procharged C-6
    By FFP in forum Gen IV V8 Specific
    Last Post: April 27th, 2007, 03:13 PM
  5. LTFT desired values for idle, light throttle, WOT
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2006, 12:55 PM
