Thread: super bog
    Oct 2012
    Default super bog
    This is my first boost build with tuning. The truck has a hard bog when going into boost. Fuel pressure is staying at 58psi, it appears that timing is getting pulled way down, and i am running chasing my tail so its time i ask for help.
    Lets start by its a lq4 gen 3, knock sensors are gen 3, ls3 heads, lsa blower with factory electronics, ls2 t/b, fast 65 injectors, lingenfelter fuel pump, and custom grind cam. If you guys would take a quick look and give some input i would be very grateful. I usually can figure things out, like i said its time for another set of eyes. Thanks
    Oct 2012
    Sometimes it takes a break....totally miised table b5911.
    Also fix these:
    Out of Range calibration summary: 08:37:00 am, Thursday Jun 18, 2015
    EFILive Custom Calibrations
    {A0001} Forced Octane Scaler Percentage, was out of range when loaded.
    {A0002} Octane Scaler Limiter, was out of range when loaded.
    There's trick to it: set the OOR cells to some value well within range, save file, exit tunetool, restart tunetool, set those same cells to desired value, save file.
    Oct 2012
    I just thought I had this issue resolved, anyway its up for a needed weekend away from cars......but I just can't seem to lay this one to rest for a few days. I rescaled map sensor fixed b5911 and reflashed. Now during reflash the AWD denali's ebtcm decided it wanted to kill high speed line so I disconnected. First initial load it seemed fixed, but I reverted to previous concern. The engine free revs and idles great. With P0856 and p1689 now setting I'm wondering if this could be my concern. I rechecked rail pressures and AFR so that's fine. The other thing I keep in the back f thoughts are these redrilled ls7 fast 65 injectors ( no data injectors) but again afrs look fine when the timing goes to crap. Thanks again.
    Oct 2012
    Quote Originally Posted by lssleeper60 View Post
    Im just wondering b5915 could be the problem or burst knock. Thanks again
    Oct 2012
    I forgot to mention in the new tune i have fixed all out ool tables as per joecar.
  1. (Super) SONIC! :)
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2011, 02:37 PM
  2. LBZ Max Boost Issues, and severe low end bog
    Last Post: August 14th, 2011, 11:16 AM
  3. 2009 Lacrosse Super 5.3
    By suark in forum E37, E38 & E67 PFI ECM's
    Last Post: June 17th, 2010, 12:35 PM
  4. The new install tool is super.
    Last Post: July 20th, 2008, 06:07 AM
  5. WOT bog from a stop. Lean Spike. Ideas?
    By tunedportcj5 in forum Gen III V8 Specific
    Last Post: December 1st, 2007, 04:46 PM
