Thread: where are the cos?
    Nov 2014
    Default where are the cos?
    step 3 of the tutorial sais "open the *.tun file from the above list... . where do i go to do that? where is that list of cos i can download?
    if i go to calibration window/upgrade os, its blank, nothing there (in 7.5 tune).
    os 12597506 and latest software (downloaded 2 weeks ago) here.
    thanks
    The COS's are already present in your V7 software install...
    My Documents\EFILive\V7.5\Bins\Custom OS
    That's not how you upgrade to an LS1B COS... (the LS1B COS tutorial does not even say to do that).
    Nov 2014
    found them, thanks.
    Nov 2014
    i will be attmpting to go from os 0125001 (2000 c5 corvette, stock) to 02020003 cos.
    i understand i have to fully flash in os 12212156 and then fully flash in cos 02020003. i read somewhere: "if your 2000 tune is stock, then you would flash in a stock 2002 tune ... . so now that i know where to find the cos, the question is:
    where will that os 12212156 or the stock 2002 tune come from?
    Start with TuneFileDepot.com, there should be a 2002 Corvette base there you can start with. You will need to copy some values from your 2000 tune to the 2002 one as GM made some minor changes (Im not that familiar with that era of Vette unfortunately), then you can full flash the 2002 stock OS. Read it back out, then full flash the COS that is compatible with that year/model/OS. Now you can cal-flash the stock calibration in then read out the COS+2002 stock calibration to use as your base tune. Im paraphrasing the LS1 COS tutorial, if there is conflicting answers then refer to that guide instead.
    Nov 2014
    good to know where the os are. thanks. i was able to download os 12212156 and im looking at it.
  1. Is there any COS for e38 other than the ethanol COS ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: July 8th, 2012, 09:54 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. Help with COS 5
    By RacerChris in forum Gen III V8 Specific
    Last Post: November 8th, 2008, 01:28 PM
