Results 1 to 4 of 4
Thread: scaling 2.5 bar MAP sensor in an E92
    Jan 2006
    Default scaling 2.5 bar MAP sensor in an E92
    Hi guys, I am using a ZR1 MAP sensor for a boosted C7, if I scale it to the normal 312.5 it's way off.
    If I scale it to 500 it is at 100 KPA KOEO, but it still isn't scaled correctly. I can drive down the road at light throttle and see 10 KPA, 0 on decel. Never goes over 40 with normal driving and it has a small cam.
    I do not have a C7Z file yet to look at, but does anyone have any experience with how to scale this correctly?
    Thanks in advance.
    I don't know if it is a different P/N but the MAP sensor in the Twin Turbo LF3 (also E92) is scaled like this...
    {B2101} MAP Sensor Scaler = 450.000000 scaler
    {B2103} MAP Sensor Offset = -15.000000 kPa
    Jan 2006
    Thanks Ross, I spoke to Jesse he gave me suggestions to correct the offset.
    Thanks for your time. I'll post my results once I have it dialed for others.
    Jan 2006
    Update. I rescaled it back to 312.500, normally in the E38 this sensor has an offset of -11.25.
    In the E92 to get it correct I had to set the offset to -1.8, I am at sea level so I brought the number to where KOEO was 100.0 KPA.
    I have only used whatever offset GM used for that sensor or any other, so I never realized that the offset number would throw the sensor off that much. After a test drive all the numbers look normal in both boost and vacuum.
  1. Scaling the ls3 map sensor??
    By rpmauto in forum Gen III V8 Specific
    Last Post: November 16th, 2012, 07:13 AM
  2. ZR1 Map sensor scaling
    By 9secVette in forum E37, E38 & E67 PFI ECM's
    Last Post: October 10th, 2010, 04:49 PM
  3. 3 bar Map Sensor
    By etmotorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: October 8th, 2010, 12:52 PM
  4. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 27th, 2010, 05:21 PM
  5. 3 bar map sensor
    By Delco in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 5th, 2007, 07:18 PM
