Weird that the temp only setting on the earlier OS works but not on the later one, either way I've added in the parameters it needed for all E92 OS's for the next release. There was a barometric pressure check as well, I just set that so that you would have to have your Vette at the earth's core before it is enabled
Thanks for letting us know the change fixed it. I can't believe GM still have that archaic system in place.
We threw a few options in there just to make sure
