Results 1 to 4 of 4
Thread: Scenning just AFRs
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default Scenning just AFRs
    I want to do a log of a 55 Chev with a 350 Chev and just log afrs from my PLX. Is there some way i can get the scanner to do this??
    Oct 2005
    Can you use just the plx software?
    The LC1 has its own software that supports logging direct.
    Maybe use this? http://www.plxdevices.com/PLXLoggerSoftware.htm
    2014 VF SV LS3 Maloo.
    Quote Originally Posted by Flyer
    I presume the Chev is not OBDII...
    The EFILive software "assumes" that it will always be connected into an OBDII connector with 12V, ground and data. So unless FlashScan is connected to an OBDII compliant vehicle then it won't log any data from the external A/D inputs.
    It is something that will be supported with FlashScan V2.
    Nov 2005
    Cool about V2
    I dont think i have any PLX software. or any way of getting its input into the PC other than via the EFIlive BB.
  1. AFRs and Turbos
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 27th, 2006, 03:44 PM
  2. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
