Results 1 to 2 of 2
Thread: Help with getting to the bottom of TPS problems!!
    Mar 2013
    Default Help with getting to the bottom of TPS problems!!
    I've been fighting this since 2012. An 05 Chevy Avalanche throwing P0120 P2135. First in 2013 dealer put a throttle body on it, then in 2014 they put new wiring/connector on it! Now over the weekend I got just the P2135 3 times within 50miles. This thing only gets drove 5k a year max, so it only has 10k-15k since new throttle body! This is the first time i'm able to look into this with my efi v2. I mainly use if for flashing diesel tunes and some diagnostics. So how can I check to see whats going on? So before I start throwing parts at it, how do I check the TBS with the v2 to see if its working properly? I checked the connector, shows its good, I'm getting 5 volts from the TAC, im getting a good ground, I checked the output of TPS, getting 1.21V.
    Do you have a GM Service Manual for your vehicle...?
    Have you seen stuff like this: http://www.obd-codes.com/p2135
  1. SAE TPS and actual TPS opening %?
    By O1Z06 in forum Petrol / Gas
    Last Post: February 2nd, 2011, 04:28 AM
  2. Alpha N (TPS Load) help... noisy TPS signal?
    By Tomato in forum Gen III V8 Specific
    Last Post: July 4th, 2008, 10:22 PM
  3. Bottom line V1 vs V2...
    By eboggs_jkvl in forum FlashScan V2
    Last Post: November 24th, 2006, 05:39 PM
  4. PE tuning..lean on the bottom..
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 22nd, 2006, 02:37 PM
  5. VE Multiplier vs. TPS vs. RPM table, with non-linear TPS...
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:46 AM
