Results 1 to 9 of 9
Thread: Cell tracking E78
    Apr 2015
    Default Cell tracking E78
    Curious if anyone knows of a "secret PID" or combination that allows the tune tool to track the timing cells live.
    For example, watch the high octane table live and see which cell its pulling from live.
    I have the KR, Timing Cylinder 1, SEVRET (torque reduction retard) and such all being logged which are good to tune from but would be nice to track them live if possible?
    thanks in advance,
    Rh
    Apr 2015
    Ill take that as a no.
    Obviously I can watch the cells in the KR map in the scan tool but didnt know if EFI had the intelligence to follow the final actual computed timing and highlight the active cells its pulling from while your driving/dyno etc.
    _R
    Senior Member Dieselman's Avatar
    Apr 2010
    I can get this to work with my E38 tune and log. Need to make sure you activate the "Automatically Track Scantool" tab
    Not too sure if this is what you are after ?
    https://www.dropbox.com/s/ten6nmx95b...Trace.mp4?dl=0
    The should be a file E78_Link.ini where you can define the link pids for each table (if not already defined).
    Look in here: C:\Program Files (x86)\EFILive\V7.5\Configuration
    If there is no E78_Link.ini, then you may be able to create a basic rudimentary one, refer to E92_Link.ini for example.
    Apr 2015
    Joecar, there is not an E78 file.
    I used the E38 and did a find replace and spot checked a few things. I am going to test it out it appears the tables in the E38 and E78 are all mapped the same, but as mentioned I did a spot check on about 20 of them not 100%.
    Ill report back.
    I attached it as a .txt to upload it.
    Apr 2015
    Excellent I will try this out this morning.
    Dieselman that's exactly what I am after and I did press the track linked cells button. It works on the t43 trans controller but not the E78.
    Joecar, I'll look for the link file and edit it. I bet that's the issue.
    Thanks again guys.
    You can create one, use one of the existing ones as a template, you can start with only the tables you want to look at.
    Apr 2015
    I used the E38 as a template and it works like charm thus far!
    Thanks a million for the help man thats the support a newb (to EFI Live) like me needs.
    Good job
    Also note that for each table axis you can have multiple/alternate link pids, each one is separated by a comma.
  1. tracking down missfire
    By Black'Rado in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2011, 04:50 AM
  2. tracking multiple maps
    By limited cv8r in forum General
    Last Post: August 13th, 2008, 09:08 PM
  3. Cell tracking with the RoadRunner
    By Whippled 496 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 15th, 2008, 03:53 AM
  4. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  5. cell by cell ltft
    By ahall1 in forum General
    Last Post: June 23rd, 2005, 06:17 AM
