Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 4l80e PI3800 triple disk chatter off idle
    Aug 2010
    Default 4l80e PI3800 triple disk chatter off idle
    Figured i would move/add this thread under here.
    Here are some specs
    2005 5.3L, Ls6 cam, gt45 turbo
    3.23 rear
    1997 4l80e rebuilt with hd2 kit
    Precision industries 3800 triple disk
    Everything seems to be good except when im pulling away from 1st gear. You can hear a grinding/rattling noise until like 5mph or so. unsure if its a line pressure issue?
    Basically took a stock 2002 van 4l80e tune, upped the line pressure around 5-10%, upped the shift points and lowered the desired shift times.
    I have never tuned an auto before. Any help?
    Jay
    My current tune (bit rich) and latest log is attatched. Mind you the log is mostly 4th gear with a couple 1-2-3 shifts later in the log. Dont mine the 4 degree retard, Im thinking my exhaust touching the frame rail and poly mounts are causing that.
    Attachment 18544
    Attachment 18545
    The pressure regulator can sometimes buzz, but it sounds like a buzz and not a rattle.
    Thinking about it, the rattle may be related to the flex plate.
    Someone tells me it might be gearset noise.
    Did it just start happening, or was it always happening.
    Aug 2010
    Litterally just thought of it. I got a TCI flexplate and totally forgot to grind the powdercoat off. Gonna check the bolts tonight.
    Also to add I only have like 60km on the car it started happening pretty well after my first outing. Drove the car around (maybe for 5min) then brought it home to work on the power steering. Next outing I drove around and did a couple 60% throttle 4psi or so pulls then noticed it the first time I was at a complete stop then started moving at like 4% throttle.
    My friend said his Firebird did the same thing after installing the same flexplate. Took a couple outings then they all backed off.
    Jay
    Quote Originally Posted by jay_rich View Post
    The flexplate bolts backed off, or the TC bolts/nuts...?
    Aug 2010
    His flexplate bolts backed off.
    Well just looked at mine. Not the case everything seems good and tight :(
    Jay
    Aug 2010
    Just hooked up a pressure gauge to the port.
    185psi Park
    185psi Drive
    270psi Reverse
    Safe to say I dont need more line pressure. Kinda lost now.
    Jay
    Aug 2010
    Looking over my log I noticed my TCC switch is wired backwards. I mixed up my ground and brake switch wire on the relay (1987 camaro so I had to change the output to be ground when pressed) That solves my Lockup not coming on. Unsure if it will have any effect on the low rpm chatter.
    Jay
    Your line pressure is a little high, but its ok.
    The TCC override switch being wired backward should not cause the TCC to make noise... but listen anyway to see if there's a difference now.
    Jan 2013
    If you drive around in manual first is the noise more prevalent? If so it is more than likely just a noisy gear set. Some 4l80 have straight cut gears usually 4l85e out of a heavy duty applications, and for some reason 2500 vans.
  1. Vibration/chatter under hard acceleration
    By LostCause in forum Lounge
    Last Post: January 20th, 2010, 02:42 PM
  2. VS Commodore wont detect chatter
    By IBLOWN in forum EFILive V4
    Last Post: August 4th, 2009, 10:44 AM
  3. V4 wont display chatter on vr commodore v6
    By Kevvrv6 in forum EFILive V4
    Last Post: March 12th, 2009, 05:11 PM
  4. Triple Dog stuck in my PCM???
    By WildChild in forum General (Diesel)
    Last Post: July 9th, 2007, 06:47 AM
  5. D2905 with triple disk TCC?
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 27th, 2007, 07:57 AM
