Results 1 to 10 of 17
Thread: How to make High idle work
    Default How to make High idle work
    Hey guys,
    I have a 2003 tahoe and im trying to figure out a way to get it to idle higher for winching and such.
    Would it be possible to put a 5 prong relay on the IAT sensor and when its energized let it read straight to ground which should be about -40* and i tune that section (B4603) (B3618) (A0008) for a higher idle??
    any other tables that would need adjusting?
    Im running COS3 also.
    Thats the only way i could think how to do it.
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    i think the best way would be a solenoid, like the 70's cars used, messing with the ECU is generally a bad idea. ther is a product called "auto throttle" senses when battery voltage is below a set threshold, then brings the motors rpm up to stabilize the voltage level
    here is one - http://www.kussmaul.com/091-84.html
    and another http://www.vanner.com/manuals/02045.pdf
    The second one wont work with a DBW throttle..
    The first one looks like it might work but i dont see how it would work with DBW also.
    Mar 2009
    Always wanted to do it in the tune myself as well but could never come up with a way to do it safely and effectively via driver input. But Off Road Engineering does make a user adjustable high idle box that's plug & play for the 03-up DBW GM's.
    http://www.offroadengineering.com/product-gmsuv.html
    Jan 2014
    what about a segment swap? from a vehicle that had a PTO or similar?
    you still using A/c?
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    I wonder if you could use an 8.1 operating system, and then retune it for the LQ4?
    8.1 OS's support factory high idle via the cruise control buttons, for PTO use in the HD pickup trucks.
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jan 2014
    Is the 8.1L the only engine offered with PTO?
    is the 8.1 coil on plug with high res crank trigger? or is it 4x with a dizzy?
    hrm.
    Jan 2014
    I don't think a controlled vacuum leak will work. It will just make it run like crap.
    You need to tip in the throttle some how.
    Using the a/c circuits is one way. or an OS that had PTO or some 3rd party stuff.
    Is the pedal a potentiometer or an encoder?
    Nov 2005
    Quote Originally Posted by RADustin View Post
    hrm.
    8.1 is coil on plug and drive by wire. Its basically identical "electrically" and "controls" wise to an 03+ drive by wire LSx. You'll just have to do some custom tuning to make the ECM work with a smaller displacement engine.
    You might have to use an 8.1 throttle body and TAC module too, I dont know if the 8.1 ECM calibration will work with an LSx throttle body and TAC module.
    The ECM's are the same (LSx and 8.1)...I mean for grins, you could just reflash your current ECM with an 8.1 calibration and see what happens????
    12.9s @ 108 mph
    Nov 2005
    Its a potentiometer...but there are THREE, and they all sweep at different ranges/directions...so it would be somewhat complicated to make a fooler.
    12.9s @ 108 mph
  1. High idle???
    By Dougal in forum Cummins 6.7L
    Last Post: September 12th, 2012, 01:42 PM
  2. LQ4 single turbo e85 cannot make it idle... Help..
    By carlsonauto in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2012, 07:47 AM
  3. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
  4. Is there a way to make the pcm use the p/n idle airflow tables?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: December 26th, 2005, 03:11 PM
  5. How do I make my idle speed operate in closed loop?
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: February 10th, 2005, 04:57 PM
