Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: CM2200 bench harness pinout
    Nov 2005
    Default CM2200 bench harness pinout
    Does anyone have a 2010-2012 CM2200 bench harness diagram that they could share?
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Nov 2005
    I think I found the correct diagrams...can someone confirm for me?
    All on the GRAY connector.
    ground...pin 2, pin 4, pin 6
    battery constant...pin 3, pin 5
    ignition-on trigger...pin 71
    CAN-C (low)...pin 18
    CAN-C (high)...pin 35
    I assume the J1939-CAN pins are not used with EFILive, and its only the "CAN-C" circuits that go to pins 6 and 14 on the OBD port...
    12.9s @ 108 mph
    Feb 2011
    All you need is:
    2 GND
    3 +12V
    18 CAN-
    35 CAN+
    70 IGN
    Quote Originally Posted by 1906 View Post
    All you need is:
    2 GND
    3 +12V
    18 CAN-
    35 CAN+
    70 IGN
    I agree, this arrangement works fine for our bench ECM's too. We also have 71 to IGN but that might not be necessary, s4door if you are having no luck it might be worth hooking pin 71 up as well to switched +12V.
    Oct 2014
    I have tried using both pins 70 and 71 with no luck. Is it possible it is security related? No SKIM or WIN modules present? I assumed that a bench setup over-rode any factory safeguards. On another post I stated that this was a used ECM that came with the rest of the package, motor, injectors ect. My source said he would replace this one if I wasn't able to get it flashed.
    May 2022
    Hey sorry to jump in but maybe you can help me out I
    Nov 2005
    Got it, thanks!
    12.9s @ 108 mph
    Oct 2014
    I have tried this on my CM2200 and I am unable to establish connection with the ECM. I get $0549 error. Ignition is switched off. I was assuming Pin 70 & 71 are switched 12v+ is that correct?
    The ECM does not need any other modules on the CAN bus, the ECM should communicate totally standalone. I assume you are on the Grey connector and not the Black one?
    Oct 2014
    Yes, the grey connector
  1. Cummins Bench Harness pinout (pictures)
    By vortecfcar in forum Cummins 5.9L
    Last Post: September 2nd, 2012, 04:57 AM
  2. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 10:33 AM
  3. bench harness
    Last Post: June 15th, 2006, 04:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 08:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 02:25 AM
