Also, do you guys have egr on your engines as well? I also see that in the wiring diagrams from the gm website
Sent from my Nexus 6 using Tapatalk
That throttle lag is in your torque limiting tables... In the USA one table number is B5100 Torque Limit By RPM... For me, I took those values and maxed them out to 886... HUGE improvement... There was a lot of lag built into the tune by gm in the USA... The table where off idle lag is on my ecm is B5103torque limit by RPM and Coolant Temp.. There were torque numbers as low as 239 ft lb@600rpm@176
My truck does the same thing from time to time. My guess is it comes up based on miles. Kinda like the maintenance burn that Ross suggested. Be nice if we had the ability to kill that CAN message cause even though it isn't actually regening it does make the DIC useless until next key cylce.
Dan's Diesel Performance
www.dansdieselperformance.com
