Page 12 of 32 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 317
Thread: EFILive 2.8L Duramax E98 ECM Support
  1. #111
    Quote Originally Posted by hacklerjason View Post
    Do I need a specific version to access those? I'm on v8.2.2.203
    Well lets just say I see them defined in the V8 GM PID list, but I cannot say exactly when they were added.
  2. #112
    May 2016
    Well I have the newest non-beta software out... I don't see them in the pid list... Even when searching for just egr, nothing of that nature pops up... Can we consider that a bug report instead of a feature request then?
    Sent from my Nexus 6 using Tapatalk
  3. #113
    May 2016
    Are they sorted in the software by the OS number? If yes, I have a different OS than you guys
  4. #114
    Right, I think that is indeed the problem, we may have populated the supported PID list from an export OS early on. I'll get this sorted for the next update (which should be this week).
  5. #115
    May 2016
    Thank you much
  6. #116
    Feb 2006
    Just so im not wasting your time, but you might be able to answer this.
    Pid - MINJSC1 - Start of Main Injection Cyl1-4 etc. Should that match the SOI maps or is it telling me when it's started injecting to be fully sprayed by the requested Injecting event or is it neither?
    I'm trying to work out if the later 17 model calibration is using a different Pattern besides the defined 1 & 2 SOI maps because the data doesn't line up.
  7. #117
    May 2016
    Quote Originally Posted by Tre-Cool View Post
    Start of main injection should indicate the timing in which it starts the main injection hahaha... Not to be sarcastic... I'm sending a pm
  8. #118
    Oct 2016
    I have the fix... Text me for details... Its not software, its in the wiring... I tested it today.. It completed a regen successfully... It no longer says cleaning filter, continue driving ... Pm for the number..
    I would like to contact you, but I cant figure out how to send a pm
  9. #119
    May 2016
    Quote Originally Posted by trucks View Post
    I tried to PM you and I got an error that you chose not to receive private messages.. If you need the link to my write up lmk
  10. #120
    Oct 2016
    Not sure why it doesnt work
  1. Duramax EGR block using EFILive?
    By asm in forum Diesel
    Last Post: March 10th, 2016, 03:26 AM
  2. ecm support needed
    By rubbersidedown in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 28th, 2014, 11:13 AM
  3. E92 ECM support released
    By GMPX in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 5th, 2013, 12:52 AM
  4. New E83 ECM Support, testers needed.
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2011, 02:40 PM
