hello there i made a dsp5 tune and am trying to make tune 5( program 4 ) have a little more fuel than tune 4 ( program 3 ) i have almost identical file on a similar truck and that truck smokes a ton... the truck in the log below has a small cloud at initial throttle but clean the entire way through... while playing the data log and having the tune open at the same time I'm seeing that the commanded MM3 is only between 20-30mm3 on the ignition pulse yet under the throttle based quantity it shows 110mm3 I'm slightly confused what it limiting the fuel..
fell free to go over and let me know what you think.. i understand the injection amount it slightly high for injectors
DSP5 attempt 3.ctz
Log_0000.efi
