Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Known issues with July 08, 2015 Public Pre-Release
  1. #21
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    I'm having a problem with Scan & Tune BBX. I change properties from Metric to Imperial and names from ECT to Coolant,etc. and save the file as options.txt. When I reopen Scan & Tune and look at the PID list my changes are not there, however after closing Scan & Tune and opening the options.txt file, all my changes are still in the file ?
    Thanks!
  2. #22
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Datalogs from cummins controllers will only display metric units for pressures in the v8 scan tool. You can change the display units, but the data values stay the same (mpa for rail pressure for example).
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  3. #23
    I'm seeing a few problems in V8 S&T in relation to BBX:
    V8 S&T BBX:
    Alarms:
    alarms are not imported from file nor from V2;
    when I try to edit/enable an alarm, it is not saved in the BBX properties, and not saved to file, it disables the alarm in the file (overwrites it).
    Custom Units:
    CU's are not imported from file nor from V2;
    when I try to edit/enable a CU, it is saved in the BBX properties, and it looks like it saves to file, but the other CU's are disabled (overwritten).
    see attached BBX config file...
    PSL_01 is where I tried to edit KR's alarm and EQIVRATIO's Custom Units via the V8 S&T BBX gui...
    the other PSL's are untouched, these show what PSL_01's pid's alarms/CU's were before I edited PSL_01 via the BBX gui.
    https://forum.efilive.com/attachment...8&d=1437269664
    it deleted the alarm and custom units from my previous PSL_01.
  4. #24
    Aug 2013
    Quote Originally Posted by Dirktdolman View Post
    Did anyone else receive this message from their Anti-Virus?
    Attachment 18645
    Webroot are known for giving a lot of false positive detections.
    This is a couple of years old, but it will give you an idea of how bad they are...
    http://www.av-comparatives.org/wp-co..._201209_en.pdf
  5. #25
    Attachment 18645
    There should be nothing in that exe that triggers such a warning, the file may be infected.
    Can you zip the EFILive_Hapi.exe file and send it to me at paul@efilive.com. I will compare it against a known good copy.
    Or if you prefer, you can check the MD5 hash yourself.
    MD5 of EFILive_Hapi.exe build 279 is 6bd1831d92b70c8b6524fb944f700529
    Use this utility to check: http://winmd5.com/
  6. #26
    Member Dirktdolman's Avatar
    Oct 2014
    Looks like they are a match. thanks
    2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
  7. #27
  1. July 08, 2015: EFILive Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
  2. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  3. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  4. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
  5. Public Release Update July 03, 2011
    Last Post: July 17th, 2011, 08:21 AM
