couple things going on. For 1mb...
I know nothing about a/c over databus as I focus on swaps into older vehicles.
But- say you want the PCM to run the fans when the a/c kicks on. If you run the standard van setup(van ecm, van OS, and van wiring) with discrete inputs and simple binary switch, the fans will never work. You have to have the pressure switch and have it functioning in the OS for the fans to be kicked on.
The van OS isn't setup to read in and use the pressure switch, so basically the van OS is out. The truck OS/ECM will work with the pressure switch, but is technically only databus controlled. If you wire in discrete inputs to the truck- the ECM simply doesn't have the hardware to signal anything.
So the trick is to use the truck OS on a van PCM. It will accept discrete inputs, read the pressure switch, and cycle fans.
All LS1b cars use variable displacement compressors. Trucks use fixed displacement. Look it up.
http://ls1tech.com/forums/conversion...ble-fixed.html
http://ls1tech.com/forums/conversion...mpressors.html
