Results 1 to 5 of 5
Thread: Calc.MAFT applying map to ve table
    Jun 2015
    Default Calc.MAFT applying map to ve table
ID:	18616Click image for larger version.
ID:	18617Click image for larger version.
    hi all, new to tuning and very new to efilive,
    I have followed the calc.maft tutorial logged a run applied filter copied with labels and pasted to b0101, but i think I may be missing something
    the corrections don't seem to be right,
    ls1b using a v2/innovate lm2with serial output,
    I have attached corrected ve table,pid list,map with filtered correction, any help would be great please,
    Nov 2013
    I am doing calc.vet, and the values it calculates for me are grams per cylinder. It looks like the values you have are multipliers. I'll read up on this when I get to work tomorrow, but someone will probly correct me before then.
    Quote Originally Posted by Mullnz86 View Post
    Map pic does shows filter not applied...
    post your log file and the tune file it was logged from.
    Quote Originally Posted by Jetmech442 View Post
    You did Calc.VET which gives you a map of VE in g*K/kPa...
    he did Calc.MAFT which gives him a map of VE in correction multiplier...
    this illustrates the differences between Calc.VET and Calc.MAFT (they are the reverse of each other).
    Nov 2013
    Thanks Joe! Hey I was mostly right...ish
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. SELBEN pid not available. Trying to setup calc.maft
    By SLP IROC-Z in forum Petrol / Gas
    Last Post: May 2nd, 2015, 09:57 AM
  3. VE Map after CALC.VET update
    By Tinbender59 in forum Gen III V8 Specific
    Last Post: September 14th, 2014, 05:35 PM
  4. trouble accessing calc.vet map
    By Bill00Form in forum FlashScan V2
    Last Post: December 2nd, 2011, 05:37 AM
  5. CALC. VE Table help
    By nchristian in forum Gen III V8 Specific
    Last Post: January 28th, 2011, 09:18 AM
