Results 1 to 10 of 14
Thread: Clarification on which PCM to use?
    Default Clarification on which PCM to use?
    Ok, got a couple conflicting comments:
    http://mcspeed.homestead.com/Modern_Moddin.doc says (see attachement) which basically states that the E67 can support a 4L60E/4L65E etc trans and the E38 can't. The statement below stays neither can.
    And http://www.hotrod.com/techarticles/1...ck_engine.html says:
    The E38/E67 ECM no longer incorporates control functions for the electronically controlled auto trans (including the 4L60E, 4L65E, 4L70E, 4L80E, and new six-speed automatics), which must use GM's new standalone production TCM. Alternatively, GMPP and TCI market standalone computers for controlling the late-model electronic automatics.
    Ross sent me an 08 E67 for the Trailblazer I6 motor and it does NOT have trans support. Since the previous P10 and P12 controllers did, I think GM is planning on going with 2 separate controllers now, an ECM and a TCM.
    Is there any advantage of having separate controllers?
    Not that I know of now, all I know is it shot down my PCM swap idea because having to wire 2 controllers vs 1 would be a royal PITA.
    So basically none of the E38's and E67's have trans support?
    Quote Originally Posted by ScarabEpic22
    Well I know for sure the E67 doesnt as since GM introduced the LL8 motor in late 01 they have used 1 PCM to control everything and now they arent... Also, the TrailBlazer SS (6L LS2) uses the E38 and a T42.
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Quote Originally Posted by N0DIH
    The key is you have to use a PCM, not an ECM. If the controller is an "E" series (E40, E38, E67) it is an engine controller only: "T" series controllers (T42, T43) are transmission only and "P" series controllers (P10, P11, P12 as well LS1 PCMs) control both engine and transmission.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Nov 2006
    what engine , wire harness, and vehicle do you have?
    you will need to match the wire harness and the reluctor wheel to the ECU.
    I am trying to setup a 0411 PCM on a 99 K2500 Suburban (OBS) 454/7400/L29 and a 4L80E.
    The L31 tune from 2002 is a good base, and supports 4L80E and the 350/L31, but I might need to tweak the wiring some with my 454. Hopefully not....
    Feb 2013
    Hello N0DIH I too have an L29/ 4L80E but in a 96 2500 Suburban. I am having trouble with a case learn and need a good base tune for my 411 swap. Have you got anything you would be willing to share. It seems that all the threads I have found so far stop once someone figures out their problem but the solution never makes it to a thread. Perhaps 3 days of searching is just not enough yet, I guess I will keep on going.
  1. clarification on semi closed loop SD
    By Cablebandit in forum Custom Operating Systems
    Last Post: October 5th, 2009, 01:51 PM
  2. AutoVE MAF calibration clarification needed
    Last Post: August 25th, 2006, 10:20 PM
  3. Going MAFless (SD mode) - Clarification needed
    By emarkay in forum General (Petrol, Gas, Ethanol)
    Last Post: March 24th, 2006, 09:09 AM
  4. Need a Down Under Clarification
    By TAQuickness in forum Lounge
    Last Post: February 25th, 2006, 07:58 AM
  5. Injector flow rate table - clarification sought
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2005, 11:08 AM
