Thread: Security light
    Jul 2015
    Default Security light
    Any fix for security light coming on? Seems like every 01/02 I flash that fails will set the security light. I've tried updating vin and re linking vats.
    Dec 2005
    Post the stock tune read out with the security issue.
    I bet the BCC is corrupted
    www.mscservices.net
    Jul 2015
    Well it was tuned previously, but what read out do you need to see?
    Jul 2015
    I read the tune, and like you said. BCC had all question marks. Currently reflashing after updating with correct code
    Dec 2005
    Most likely the ecm is corrupted, the security light will not go out until the BCC shows correct.
    If you use that tune and flash any other ecm with it the ecm will also be corrupted.
    LB7's need the flash chip pulled and off board programmed to repair them, SoCal Diesel has a repair service.
    It will most likely run but that junk BCC is causing the security light.
    www.mscservices.net
    Jul 2015
    Ok, thanks for your help
  1. Persistent security light
    By vortecfcar in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2012, 07:59 AM
  2. Replies: 1
    Last Post: February 2nd, 2012, 09:58 AM
  3. Security Light
    By ZR2_350 in forum FlashScan V1
    Last Post: August 8th, 2010, 03:23 AM
  4. Code U1000 Security Light on No start. HELP!!!
    By ls698ta in forum Gen III V8 Specific
    Last Post: February 14th, 2009, 09:28 AM
