Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: LS3 engine Injector Bank assignments..... letters versus numbers
    Sep 2013
    Default LS3 engine Injector Bank assignments..... letters versus numbers
    Question regarding this table...... does anyone know if A=cylinder1, B=Cylinder 2, C=Cylinder 3, etc. Seems like it should show Bank 1 injectors as A-C-E-G for 1-3-5-7. Instead it looks like bank 1 and bank 2 injectors don't correspond to bank 1 and 2 cylinders.
    This is in a 2010 Camaro, 18 lbs boost on a TVS2300, squash twin fuel pumps on a return system, wet nitrous with direct port injection.
Name:	Screenshot (223).png
    Sep 2013
    The problem I'm trying to correct is bank 2 wideband AFR runs about .5 AFR higher than bank 1 only on WOT during 1/4 mile data logging. Narrowband sensors are off about the same percent. Narrow band sensors were swapped and the problem doesn't follow. Both wide bands have been recalibrated. Next step is to swap widebands and recalibrate to open air for about the 4th time, but not expecting a change since the narrowband swap proved the difference I think. I was thinking of doing an individual injector correction, but stumped by the letter to number correlation. Exhaust and intake have both been smoke tested for leaks and everything is sealed up good.
    Sep 2013
    My theory is fuel is supplied to bank 2 fuel rail and then flows out both ends to bank 1.... I think bank 2 gets a scavaging effect that lowers the fuel flow versus the dead ended bank 1 under higher flow conditions. Problem occurs with or without nitrous on..... so nothing to do with nitrous jetting.
    Aug 2013
    Quote Originally Posted by Blue70SS View Post
    I think the A-H follows the firing order.
    Sep 2013
    Thanks Statesman,!
    So sounds like this: (the "2-6" in the firing order explains the odd diagram)
    1-8-7-2-6-5-4-3 Firing Order LS3
    A-b-C-d-e-F-g-H Letter assignments
    1-2-1-2-2-1-2-1 Corresponding Bank Assignments
    So for "injector individual correction" based on lettering A through H,
    to add fueling to bank 2:
    Increase the numbers for b-d-e-g injectors
    Sound correct?
    Aug 2013
    Sounds good to me.
    This is what I have in my notes:
    Code:
    Cylinder Labels:
              2 4 6 8
      <-Front
              1 3 5 7
    Coil Labels:
              D G E B
      <-Front
              A H F C
    Injector Labels:
              5 2 4 7
      <-Front
              8 1 3 6
    Firing Sequence:
    Cylinders: 1-8-7-2-6-5-4-3 (firing order)
    Coils:     A-B-C-D-E-F-G-H
    Injectors: 8-7-6-5-4-3-2-1
    Aug 2013
    So for the injectors, A-H = 8-1 ?
    Sep 2013
    Thanks for info joecar! The 8-1 for injectors seems odd, since the "individual injector correction" page shows letters. The correction factor starts at 1.0 and goes from 0 - 2, which looks like 2=100% more and 0 = 100% less.
    So if the A-H = 8-1 holds true, to adjust by letter in the screenshot below - I would need to adjust B-D-E-G higher to compensate for bank 2 (2/4/6/8 cylinder #s)being leaner than bank 1?
Name:	Screenshot (224).png
    Quote Originally Posted by statesman View Post
    Yes, injector # follows reverse firing order.
  1. Replies: 19
    Last Post: July 26th, 2015, 05:17 PM
  2. Fuel Injector Speadsheet For LS3 to LS1 Injector
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: June 22nd, 2015, 08:06 PM
  3. Verify Fuel injector numbers for 80's
    Last Post: October 15th, 2011, 05:08 PM
  4. Bank 1 to Bank 2 Injector Pulse time
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: June 10th, 2010, 06:33 AM
  5. LS2 E38 HSV - Injector Flow Versus Delta MAP?
    By Acer in forum E37, E38 & E67 PFI ECM's
    Last Post: August 12th, 2007, 06:52 AM
