Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: High Idle
    May 2015
    Default High Idle
    Probably have this asked a lot, what I found in searches wasn't much help
    Any one have a Manual High Idle base file for an 07?
    OS 11450202
    Calibration 45325753AH
    Apr 2011
    I do have a 202 OS with high idle enabled for a manual somewhere, but it is not where I thought it was. In the mean time here is a 602 OS that can be used.
    2006 Manual High Idle 602.ctz
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    May 2015
    Awesome I will get to work haha Thanks!
    May 2015
    Sent an email, Mike
    Apr 2011
    Quote Originally Posted by DarkDiesel View Post
    Sent an email, Mike
    You should have what you are looking for now!
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    May 2015
    Perfect Thanks!
    May 2008
    Subd
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Nov 2015
    I have a 2006 auto, will this file work if my OS is 405?
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    Pretty sure that High Idle is handled by the Totally Intergraded Power Module (TIPM), at least in the 06 & 07 model years, which is not accessible via EFI Live.
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
    Nov 2015
    Ok so then I still need to have it flash by chrysler I guess?
  1. High idle???
    By Dougal in forum Cummins 6.7L
    Last Post: September 12th, 2012, 12:42 PM
  2. LMM High Idle
    By Follmer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2011, 10:25 AM
  3. high idle help
    By amiller406 in forum Duramax LB7
    Last Post: March 25th, 2011, 06:55 AM
  4. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 03:14 PM
  5. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 01:18 PM
