Results 11 to 20 of 22
Thread: High Idle
    Apr 2011
    The attached file has the manual high idle feature enabled and will work without messing with the TIPM. I should replace your 405 OS without any issues.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Nov 2015
    Quote Originally Posted by ATPCummins View Post
    Ok thx very much.
    I really appreciate the help. Just getting started with my V2 from Anarchy tuning myself. Have read almost every thread on here.
    So how would I go about pasting my tune onto this file? And I assume just enter my VIN into it to make sure it matches and I should be able to flash the truck?
    Apr 2011
    Yes, you will need to be sure that your VIN is correct as well as the anti-theft settings.
    You can copy and paste your tables over, or create a script of your current tune and run that over the new OS.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Nov 2015
    Ok I opened up the high idle file and I noticed it does say manual for transmission and mine is an automatic. So this probably won't work then...
    Apr 2011
    Auto file attached: 2006-2007 Auto High Idle 602.ctz
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Nov 2015
    Well thanks very much sir!!
    Nov 2015
    So I couldn't figure out the scripting yet so I just copied the tables over, put in my vin, and flashed the truck and it works!
    Apr 2011
    Glad to hear that it worked for you!
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  9. #19
    Dec 2015
    Awesome! I've been looking for this for a while! Works Great!
  10. #20
    May 2010
    I decided to try the auto high idle file as well. Converted to csp5 and ran a script. Worked perfect! Thank you!
  1. High idle???
    By Dougal in forum Cummins 6.7L
    Last Post: September 12th, 2012, 01:42 PM
  2. LMM High Idle
    By Follmer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2011, 11:25 AM
  3. high idle help
    By amiller406 in forum Duramax LB7
    Last Post: March 25th, 2011, 07:55 AM
  4. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 04:14 PM
  5. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
