Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: High Idle
  1. #21
    Dec 2015
    How do you run a script and transfer everything over? I just copy and pasted and that took a while..! Thanks
  2. #22
    Apr 2011
    Open your stock tune, then open your custom tune as a comparison. Click on edit, and then create script. Save the script with whatever name makes sense to you. Open the new stock base tune you want to use, and click on edit, then run script. Select the script that you just created and run. Once the script is done running save it with a new name. That is it.
    Two important things to remember when scripting: If you created the script with metric units, it must be run with the tune set to metric (or created and run with imperial). When creating a script you must use the same operating system as a comparison. Meaning that if you are creating a script for a CSP5 tune, it must be compared to a stock tune upgraded to the CSP5 OS.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  1. High idle???
    By Dougal in forum Cummins 6.7L
    Last Post: September 12th, 2012, 01:42 PM
  2. LMM High Idle
    By Follmer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2011, 11:25 AM
  3. high idle help
    By amiller406 in forum Duramax LB7
    Last Post: March 25th, 2011, 07:55 AM
  4. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 04:14 PM
  5. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
