Results 1 to 10 of 13
Thread: Can't record Analog voltages in pass through mode!!!
    Jan 2007
    Default Can't record Analog voltages in pass through mode!!!
    Tested all four analog in channels.
    On self test can see moving voltages.
    When BBX logging can see moving voltages.
    When trying to use my laptop and EfiLive Scan 7.5.7 build 283 latest version on website all I see is 0 volts on all four channels. All over PID logging and functionality appears to be working. Possible bug?
    Has anyone heard of this issue?
    PM me a link to this thread.
    Try installing V7 build 286 from here: July-08-2015-EFILive-Public-Pre-Release
    Jan 2007
    Hi Joe,
    I have updated to the suggested version in the links above. Happy to announce a partial success.
    When I try to connect to flash scan only and only select the analog 1 PID I can see the moving voltage. Hurray!
    Howver, when I select my normal PID file I get an error and can't log. I will try to rebuild my PID file to see if it fixes the issue but due to limited time resources on my side it could take a couple of days to report back.
Name:	efilive error.JPG
    Quote Originally Posted by 2002_z28_six_speed View Post
    Hi Joe,
    That "error response 5" message was a bug in an old version of the software/firmware.
    After updating your V7 software, make sure you also updated your V8 soaftware and your FlashScan firmware using the [Check Firmware] button on the main window of the V8 software.
    Post your calc_pids.txt file here.
    Jan 2007
    I can't exactly say what fixed this but the error message is not coming up anymore. Logging is working. Thanks to all!
    Stuff unhappens...
    Jan 2007
    Well junk. It seems that the fix is still partial. Some PIDs can be logged through pass through mode and other cause it to have the same error as above.
    Which pids are loggable, and which are not...?
    Post your log file.
  1. Downloaded v8 trying to scan dsp5 voltages
    By KCCORRAL in forum General
    Last Post: September 10th, 2013, 02:58 AM
  2. Replies: 4
    Last Post: March 15th, 2012, 09:51 AM
  3. DSP5 not switching voltages
    By lakingslayer in forum Duramax LB7
    Last Post: May 26th, 2010, 01:49 AM
  4. DSP5 Voltages
    By ruralgas in forum Duramax LLY
    Last Post: May 17th, 2010, 05:36 PM
  5. Innovate LM-1 Voltages.
    By curtbriggs in forum General
    Last Post: September 4th, 2005, 03:15 PM
