Results 21 to 30 of 36
Thread: Reaching out for some help on tuning
  1. #21
    Lambda (or Lambda and EQR).
  2. #22
    Apr 2011
    Any idea how to unlock the oem pcm to at least read the tune from it?
    I RATHER BE BLOWN & STROKED THAN SPRAYED
  3. #23
    Quote Originally Posted by ToXshoX View Post
    I pm'd Paul for further advice.
  4. #24
    Apr 2011
    I was hoping to drive the car this weekend but maybe i shouldn't even though it seems to run fine and well i think it's a little on the lean side of things with that locked pcm it idles @ 15 air to fuel but seems to be a weak driving like 13.5-14 giving a pull I guess i dont know how much it could hurt it to drive it like that. Wideband is in the X on the exhaust system.
    I got my roadrunner running and connected but honestly I'm not good enough to get it up and running. Especially when i have nothing to start from. But a stock tune file i got online. I had a download of a modified tune awhile back i saved but it wouldn't keep the car running either. I'm pressed against time and it gets me frustrated.
  5. #25
    You can drive it, just don't push it hard.
    For the RR you need a tune file that you read out from your PCM (but your PCM is locked).
  6. #26
    To unlock, try this: connect V7 scantool to vehicle, go Flash->Read Calibration From PCM, checmark Try Alternate Keys.
  7. #27
    Apr 2011
    I was scared so i drove it again and watched air to fuel a bit more and giving a pull it holds a 13.3 but if you shift up and lug the motor it leans out bad like 17 and then some probably gauge doesn't read it actually. At cruise set @ 65 it bounces around anywheres from 14 something to 15 might even see a 16. I guess if i drive it i might have to just take it easy and shift more try not to lug it as much. I know I'd rather take the car for the weekend but wife probably would rather me take the trailblazer ss much more laid back cruiser, and easier to drive in the city.
  8. #28
    Apr 2011
    Tried that didn't work. It kind of seems like I'm screwed.
  9. #29
    I pm'd Paul to see if he has any ideas.
  10. #30
    Apr 2011
    you messaged Paul or am i suppose to?
  1. Replies: 7
    Last Post: June 1st, 2012, 04:26 PM
  2. High RPM (3500-3900) boost issue... not reaching target??
    By GeneralTJI in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 20th, 2010, 05:58 PM
  3. 08 Silverado 5.3 Tuning, tuning-spark/pe mode/
  4. Replies: 11
    Last Post: May 9th, 2005, 12:52 AM
