Results 1 to 8 of 8
Thread: V2 on a MotorCycle?
    Senior Member Wolfie's Avatar
    Dec 2007
    Default V2 on a MotorCycle?
    I'm installing a PLX wideband on my bike. (The same one I am using in my van, modded to plug into the V2)
    Wondering if I can use my V2 to do the logging?
    Also, can I also use the a/d inputs?
    I guess what I am asking is can I use it without it being connected to the ecu?
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
    No, you need data frames to insert serial/analog data into.
    Also you need +12V battery power/ground.
    Oct 2006
    That would be nice wouldn't it, I have often wondered that myself and thought it would. I know on my Yamaha you can get to the ECU port real easily (I don't mean to try and hook it up to the port, just that the ECU has a plug-in) and 12v and ground are easy to obtain as well, the PLX should work in Digital mode on the V2.
    joecar says no, then it probably means no, but it would be nice.
    joecar can you elaborate as to why the V2 would not record data if it had power, ground and wideband data port connected?
    2006 Trailblazer
    I'm only saying no from point of view that the ECM would have to use GMLAN or GMVPW protocol.
    Jan 2007
    As a rider I would advise you to get the tuning done on a dyno. Too much can go wrong with this.
    Dec 2007
    as a "tuner" who has been tuning bikes for well over 40 years, I'm quite comfortable doing this.
    And toJoe.... POOP! now have to make/get a datalogger....
    Wolfie
    Sorry Wolfie...
    Oct 2006
    Is that protocol needed to just data log wideband output? Not wanting to log ECU or ECM output just use V2 as recording device for wideband.
    So even if the V2 was powered up correctly, the V2 still needs the send and receive of the ECU to enable data logging for the wideband data port?
    As Wolfie said POOP!
    2006 Trailblazer
