Results 1 to 10 of 19
Thread: PLX2 corrupt?
    Jul 2005
    Default PLX2 corrupt?
    My V1 stopped logging PLX2, just shows open voltage of 3.6v. Using Windows 7 in Bootcamp V7.5.7 build 283. I have an older version on my computer V7.2.7 build 236, When I review the identical log file in both versions build 236 AD2 shows correct voltage but changes PLX2 to LM1. Also both versions add two un-selected PIDS, Ext.AD1 and Ext.Temp1 Thermocouple. I load 21 pids and record 23. Attach far left build 236 center build 283 right pid selection in V1. Anyone seen this before?
    One more item. when loading pids to V1 bottom frame of build 283 scan shows generic, vin and operating system 2030003, I select controller and it shows GM-VIN-2030003 but when I connect to V1 it reverts to generic-vin-2030003.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Try V7 build 286 from here: July-08-2015-EFILive-Public-Pre-Release
    Jul 2005
    Iinstalled build 286, exactly the same corruption. I can select PLX2 pids in build 236 after loading log and they read OK.
    Ok, something broke after V7 build 236.
    I'll pm Paul.
    Jul 2005
    Thank you. I probably need to remove all EFI files and start with a fresh install. Lately when I close Tune Windows reports missing handles.
    Quote Originally Posted by purrvert View Post
    Post a screenshot.
    Jul 2005
    Won't do it now. "Invalid Handles" roughly six different dialog boxes.
    Jul 2005
    I've uninstalled both versions of scan and tune. Reinstalled build 286. It's getting worse. Six dialog boxes for 'invalid handles' appear when I close tune, all code 1400. Tune authorization set to demo but scan is not connected and tune Help register has been filled in for commercial. I'm lost.
ID:	18669Click image for larger version.
    The EXT.AD1 and EXT.TEMP1 are along for a free ride, they do not occupy any pid channels.
  1. ECM File Corrupt From My Truck To Autocal
    By maczilla23 in forum AutoCal
    Last Post: October 2nd, 2012, 01:29 PM
  2. Help with software going corrupt
    By kwhiteside in forum Gen III V8 Specific
    Last Post: October 19th, 2009, 03:33 PM
  3. Pass through logs corrupt..?
    By samh_08 in forum FlashScan V2
    Last Post: April 19th, 2009, 02:13 PM
  4. Corrupt BB data
    By RevGTO in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 05:48 AM
