Looking for ideas,I can bench flash it but not in the truck,took out radio fuse,unchecked high speed,alt keys. pretty tuff taking ecm out for every flash
Truck drives fine,logs fine guessing its another on board computer kicking it off. wow not post must be the first one
Remove fuses for OnStar, Radio, BCM.
I am up to 15 fuses still will not flash
make it 20 now,says its rearming then will fail the flash,sounds like vats maybe kicking on?
12:54:42.171: Scanning for EFILive FlashScan V2 HAPI
12:54:42.187: Autodetect interface ...
12:54:42.359: Interface firmware version: 2.7.82
12:54:42.375: Connection to [FSV2] interface is OK
12:54:42.484: USB driver version: 2.8.48
12:54:42.484: USB library version: 3.2.7
12:54:42.500: Interface firmware model: FSV2
12:54:42.515: Interface firmware version: 2.7.82
12:54:42.546: Interface firmware date: Apr 10, 2015
12:54:42.562: FlashScan serial number: 003589092993
12:54:42.578: FlashScan license number: 003543662511
12:54:42.593: Disconnecting ...
12:54:43.343: CAN-VPW Bridge Deactivated
12:54:43.343: Disconnected
12:54:44.046: Scanning for EFILive FlashScan V2 HAPI
12:54:44.062: Autodetect interface ...
12:54:44.125: Interface firmware version: 2.7.82
12:54:44.125: Connection to [FSV2] interface is OK
12:54:44.140: CAN-VPW Bridge Activated
12:54:44.203: Current protocol set to: "SAE J1850 VPW"
12:54:44.218: Autodetect PCM...
12:54:44.265: Connection to PCM is OK
12:54:44.281: Current protocol: "SAE J1850 VPW"
12:54:44.390: USB driver version: 2.8.48
12:54:44.390: USB library version: 3.2.7
12:54:44.421: Interface firmware model: FSV2
12:54:44.437: Interface firmware version: 2.7.82
12:54:44.453: Interface firmware date: Apr 10, 2015
12:54:44.468: FlashScan serial number: 003589092993
12:54:44.484: FlashScan license number: 003543662511
12:54:44.687: Getting status...
12:54:44.750: Status: OK.
12:54:45.500: Bootloader version: LS1B_v1.7C (08DC-9623)
12:54:45.500: Preparing PCM for reflash...
12:54:45.546: PCM seed is: $28D9
12:54:45.546: Unlock attempt 1 of 1
12:54:45.687: Initializing PCM...
12:54:46.468: Initializing PCM, step 1 of 4
12:54:46.468: Initializing PCM, step 2 of 4
12:54:47.234: Initializing PCM, step 3 of 4
12:54:48.734: Initializing PCM, step 4 of 4
12:54:49.796: PCM lock has been re-armed, attempting to unlock PCM again...
12:54:49.843: Not ready, waiting 1 second for retry...
12:54:51.093: Not ready, waiting 1 second for retry...
12:54:52.343: Not ready, waiting 1 second for retry...
12:54:53.578: Not ready, waiting 1 second for retry...
12:54:54.859: Not ready, waiting 1 second for retry...
12:54:56.109: Not ready, waiting 1 second for retry...
12:54:57.359: Not ready, waiting 1 second for retry...
12:54:58.625: PCM seed is: $28D9
12:54:58.625: Unlock attempt 1 of 1
12:54:58.765: Initializing PCM...
12:54:59.531: Initializing PCM, step 1 of 4
12:54:59.531: Initializing PCM, step 2 of 4
12:55:00.296: Initializing PCM, step 3 of 4
12:55:01.796: Initializing PCM, step 4 of 4
12:55:02.828: PCM lock has been re-armed, attempting to unlock PCM again...
12:55:02.984: Initializing bootloader...
12:55:03.062: Error: Failed. Controller has returned to normal operation, please retry the operation.
12:55:03.296: Initializing bootloader, step 1 of 5
12:55:03.296: Error
12:55:10.546: PCM is in an unknown state.
12:55:12.656: Clear emisison related DTCs...
12:55:12.687: Clear DTCs for all modules...
12:55:13.484: Disconnecting ...
12:55:13.890: CAN-VPW Bridge Deactivated
12:55:13.906: Disconnected
12:55:13.906: Data transfer was interrupted.
12:55:18.421: Done!
the flash log
With every fuse I can pull and still have it connect and alt. keys ,unchecked high speed it went though ,I try putting some fuses back that I didn't know what they where and it failed after 5 min flash dam didn't think the bench flash would save me but looks like it took it,so how can I pin point what system is causing the problem besides 10 more hrs and hopefully not a cooked ecm of trying stuff
well looks like the jokes on me 7.5 doesn't work on this truck after 12 hrs, lost mark another one for the lost column
I have done 03 SS trucks before why would that get changed not like I am using beta,had the ecm out 6 times 25 fuses for a software problem ,hptuners reads it V8 works,wait Its me right lol
It looks like something is interrupting the bus...
12:55:03.296: Error
12:55:18.421: Done!
