Results 1 to 10 of 11
Thread: Why desired engine power PID not working ?
    Lifetime Member wesam's Avatar
    May 2010
    Default Why desired engine power PID not working ?
    Any body have luck with E92.REQPWR_DMA ?
    When i tried to log it it seems not supported in GM E92 Trucks
    any help will be appreciated
    EFILive Tuner
    May 2010
    Any help will be appreciated
    EFILive Tuner
    May 2010
    Strange 5 days and still no answer ?!! for simple question about one PID
    EFILive Tuner
    Dec 2005
    On the PID, you can check the needed parameters to see if there is another PID not selected that may also be needed to read correctly. The E78 has the same issues.
    04.5 2500HD LLY EC/LB
    14 Sonic RS Sedan
    GM Certified Technician
    President of the 'I killed an ECM' club
    Quote Originally Posted by a78turbo View Post
    This is what is done for calc pids... but this is not a calc pid... this is a DMA pid, these are defined only for particular OS's.
    Quote Originally Posted by wesam View Post
    Which OS id...?
    As an FYI, 'any' PID that ends in _DMA requires a lot of time for us to define, sometimes a few hours just to add 4 or 5 PID's PER ECM PER OS so you can see how they are quite demanding and unfortunately often neglected.
    I'm not sure how useful ' 'Exx.REQPWR_DMA' actually is though, it is just gives the result from the pedal > KW tables.
    May 2010
    I'm fighting to keep throttle open for a FI E92 cars
    So i think if i know how much torque the peadle request and compare it to the actual torque i can put the correct numbera in torque tables
    EFILive Tuner
    You could create a spreadsheet in Excel to convert the KW numbers to a desired torque figure, would that help?
    Jul 2003
    This is SUPER useful Ross.... and not necessarily will give out what is in the table.
  1. Reduced Engine Power help please
    By JUSTASBC in forum Petrol / Gas
    Last Post: August 26th, 2011, 12:55 AM
  2. Reduced engine Power
    By Webbs in forum Gen III V8 Specific
    Last Post: February 3rd, 2011, 09:18 AM
  3. Need help getting rid of reduce engine power!
    By Optimus Prime in forum Gen III V8 Specific
    Last Post: January 23rd, 2008, 07:36 AM
  4. Reduced engine power
    By redlinepd in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 7th, 2007, 08:30 PM
  5. Which PID's for power PID's to work
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: June 4th, 2007, 01:47 PM
