Currently known issues and possible workarounds for the August 07, 2015 Public Pre-Release of the EFILive Software and Firmware
Download the current/stable release software here: http://www.efilive.com/latest/cat/download-efilive
Download the public pre-release software here: https://forum.efilive.com/showthread...ic-Pre-Release
Public pre-release software versions:
- Software: V7.5.7.290
- Software: V8.2.2.283
- FlashScan/AutoCal firmware: V2.07.88
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2 (in July 28 release):
In the July 28 pre-release, error $0525 occurs when trying to license or flash a *.ctz or *.coz tune file using the V8 pass-thru flashing software.
The error is due to the July 28 release being built with the wrong EFILive_VM.dll file. That dll is faulty and does not recognize any files created by previous software versions.
Workaround:
Please download and install the Aug 07 update
Issue 3 (in July 28 release):
In the July 28 pre-release, BBX scan items that specify both an ECM and a TCM display no PIDs.
Workaround:
Issue 4 (in July 28 release):
In the July 28 pre-release, the V8 PID selections have been incorrectly limited to 35 channels for most CAN controllers.
Workaround:
Issue 5 (in July 31 release):
In the July 31 pre-release, an Access Violation may occur when deleting a "Scan Controller" item from the [F5: BBX] tab page.
Workaround:
Issue 6 (in July 31 release):
In the July 31 pre-release, the FlashScan/AutoCal firmware would stall when starting black box logging if more than 7 dynamic frames were required to transmit PID data from the ECM to FlashScan/AutoCal.
(Note: 7 dynamic frames is about 49 channels).
Workaround:
Issue 7 (in Aug 03 release):
Some diesel injector PIDs (defined for Black Box Logging) were not available in the V7 Scan Tool display.
Workaround:
Issue 8 (in Aug 03 release):
Some PIDs would not display negative values correctly in the V8 Scan Tool display.
Workaround:
