Results 31 to 33 of 33
Thread: Aug 07, 2015: EFILive Public Pre-Release
  1. #31
    If the tune restrictions are locked does it lock the controller (PCM) when flashed to it?
    Yes. But its an "intelligent lock".
    It is locked for reading so it can't be read out. When using EFILive (and only EFILivE), any tune file can be flashed over the top without restriction.
    • If the file that you flash over the top is not flagged as "Auto-Lock" then the controller will be unlocked after the flash process.
    • If the file that you flash over the top is flagged as "Auto-Lock" then the controller will remain locked after the flash process.
  2. #32
    Aug 2015
    is there any way to get a csp compatible version? i had it i have a few files but for what ever reason its gone. and no i didnt up date
  3. #33
    Nov 2005
    Quote Originally Posted by PHIL@ARMORINC View Post
    The release in post one of this thread is a compatible CSP version. Download it, update your software and firmware, and read the CSP upgrade document for instructions and a list of compatible base files.
    Cindy
  1. Known issues with Aug 07, 2015 Public Pre-Release
    Last Post: August 8th, 2015, 11:42 AM
  2. Known issues with July 08, 2015 Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
  3. July 08, 2015: EFILive Public Pre-Release
  4. June 02, 2015: EFILive Public Pre-Release
    Last Post: July 8th, 2015, 05:07 PM
