Results 1 to 5 of 5
Thread: Autocal Windows Driver Search ??
    Dec 2005
    Default Autocal Windows Driver Search ??
    Anyone know how to stop Windows from always trying to update the Autocal Driver ??
    Windows 7-Ultimate.
    It is a not a big deal but every new Autocal I plug into the PC to load the BBX Scripts,etc requires me to stop "Windows" manually from trying to search for and update the driver, if I do not stop Windows it takes 30 seconds to stop on its own.
    Its just one extra step I would like to avoid every-time I configure a new Autocal.
    Anyone have the answer ??
    Thanks in advance.
    Tony
    www.mscservices.net
    I'm not sure how to do that Tony, interesting situation though as I suppose Windows thinks it is a new device. Same thing happens on USB memory sticks though, buy a 4 pack of the same brand and Windows will want to install the driver on each one.
    I found this on the internet, might be worth a shot but may also have a negative effect if you tell it not to detect new devices....
    Maybe step 3 is the best option as that will stop it attempting to find the USB driver via Microsoft, instead it will just use the one already installed on the PC therefore might only take a few seconds.
    Stop Windows 7 From Installing Device Drivers
    However, you can block Windows7 from installing device drivers or permanently hide the device driver installation wizard, by following these simple steps mentioned below:
    1. When you get the prompt to install device drivers, open control panel and go to “Advanced system settings”. Select the hardware tab and select “Device installation settings” Stop Windows7 from installing drivers automatically
    2. Now choose “No let me choose what to do”.
    3. Also select the checkbox “never install driver software from Windows update”, because this will stop windows from downloading device driver updates in the future.
    That’s it, now Windows is configured to not check for available device drivers whenever an external hard drive or a USB drive is plugged into the system (this also includes USB mouse or keyboards).
    Dec 2005
    Thank You Ross.
    It was not always like that, I think when Paul altered the devices to program them "GANG STYLE" is when the issues with driver searching started.
    Prior to that change on your end for bulk programming I do not remember it ever doing that.
    www.mscservices.net
    Lifetime Member Mitco39's Avatar
    Jan 2009
    I think mine has done that for quite some time, but usually it only takes about 4 seconds or so to add the new autocal. Never really had any issues for quite a long time now.
    Oct 2006
    Can't you go into device manager and delete the entry for the AutoCal and let Winders pick it up again and it stop the searching process.
    Use to work on problem items years ago.
    2006 Trailblazer
  1. Lost search button after April update
    By ACCLR8N in forum FlashScan V2 BB Logging
    Last Post: July 3rd, 2013, 12:14 AM
  2. So MS has a search engine
    By GMPX in forum Lounge
    Last Post: July 30th, 2009, 03:38 AM
  3. did a search but questions not answered...
    By MattysTA in forum Gen III V8 Specific
    Last Post: October 17th, 2008, 05:45 AM
  4. Lean Cruise ... I did search, but ...
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2005, 06:42 PM
  5. Tell me where to search for examples, howto's, etc..
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2005, 04:33 PM
