Results 1 to 3 of 3
Thread: injector return rates
    Oct 2009
    Default injector return rates
    Is there a way i can check the return rates with efi or do i need a tech 2 ?
    Mar 2009
    Return rates are checked with a beaker set, not a scan tool. Balance rates can be checked with a V2, TECH 2, and several other high end scanners and programmers.
    Oct 2009
    So how would I go about doing a return test
  1. FAST 36# injector data for 98 corvette return fuel system?
    By myws6formula in forum Gen III V8 Specific
    Last Post: October 2nd, 2012, 04:12 PM
  2. injector balance rates
    By Hunter t in forum Diesel
    Last Post: June 11th, 2012, 12:38 PM
  3. Injector Flow rates?
    By 03svrider in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 1st, 2012, 05:20 AM
  4. Injector Flow Rates
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 22nd, 2010, 07:22 AM
  5. Injector Data for return style fuel system
    By minytrker in forum Gen III V8 Specific
    Last Post: November 26th, 2009, 03:36 PM
