Well, the weather is getting nice here in Colorado, I have a week off the end of this month (27 May - 4 June), and it is time to tune this baby up. As you can see below I have all the parts, a great car that is capable of more than it is making at this time, and time plue EFILive to do this tune right.
Setup:
2002 Vette
twin turbos
random tech high flow cats
straight pipes
Custom OS
2bar MAP sensor (GM)
AFR sensor Innovate lc-1 permenantly installed
I have a pretty good tune on the car now (thanks to Mike at Xtreme in Tempe), but before the install of the Custom OS should I:
1. Scan/log AFR and boost pressure.
2. Going to combine the AutoVE and BoostVE logging table into one table just so I can see the two tables all at once.
3. Use the logged AFR under boost to populate the 105+kPa Boost VE table as a starting point for Boost VE tuning? (Should be a good starting point, haven't made any aluminum ashtrays since I got the TTurbo tune)
Here is the hard question:
I am running 91 octane pump gas, a quart of TORCO to 18 gals every tank. I have been reading a lot about knock, and rather to throw fuel at knock or to remove timing to get rid of knock. Since I am running cats I am concerned about how much fuel I inject into the boosted MAP ranges so I don't burn out the cats. From all the reading, it seems to be fairly agreed upon that rather you add more fuel or reduce timing, the RWHP is about the same no matter which way you go.
With this in mind, I am leaning towards removing timing to get rid of any knock if I have to. You guys that have ready access to a dyno, is what I have been reading about fuel vs timing accurate as far a RWHP is concerned in your experience?
More to come as I move through this project...
Lots of questions and I appreciate the help.
Lonnie in Colorado Springs
