Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Windows 10 compatibility
    Dec 2005
    Default Windows 10 compatibility
    Can we upgrade to windows 10 and still use EFILive?
    Thx
    Yes, I've been using W10 with EFILive since last October without any issues. Upgraded to W10 RTM and still no issues to address.
    The only caution is around some USB3 controllers not working well with the FS V2 drivers, there is a workaround on the forum for it (and this isnt a W10 issue, applies to W8/8.1 as well).
    W10 is just W8++ so it should be ok (from what I can see in my coworkers' MSDN kit).
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    I upgraded to windows 10. I modified and saved a tune file after upgrading. now when I try to open it I get this.Click image for larger version.
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Quote Originally Posted by garrettg.bpd View Post
    Can you send the faulty file and the original file that you modified to paul@efilive.com
    Jun 2013
    sent
    EFILive Beta Tester
    Jan 2006
    Upgraded to W10, and no longer have communication with my V2. What is the remedy?
    Custom Tuning Services
    Apr 2005
    I am able to get a connection like 2 out of 100 tries. I keep getting this access violationerror
    Quote Originally Posted by killerbee View Post
    Check this thread out: Windows 8 Users (USB3-xHCI)
    FWIW we have a Surface 3 here running EFILive on Windows 10 with no problems at all.
  1. E40 OS Compatibility
    By SkinnyPedal in forum Gen III V8 Specific
    Last Post: April 15th, 2014, 04:33 AM
  2. OS Compatibility Question
    By Webbs in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2013, 02:22 AM
  3. Windows 8 Compatibility
    By robertleeii in forum General
    Last Post: June 18th, 2012, 03:17 PM
  4. Compatibility
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2008, 12:53 PM
  5. Viper Compatibility?
    By Donovan in forum Petrol / Gas
    Last Post: August 26th, 2008, 09:21 PM
