Results 1 to 3 of 3
Thread: Need help with Autocal error message when loading tune
    Aug 2015
    Question Need help with Autocal error message when loading tune
    I recently switched shops, had the old shop unlink my autocal, I sent it to the new shop and he linked it to his controller and sent it back to me.
    So first, I read the trans and engine files. The engine read said "OK 2,087 and ER 26". The trans read said "OK 2,067 and ER 11"
    Later on when I loaded the new tunes on from my shop the engine one said "OK 907 and ER 6" the trans one said "OK 795 and ER 3"
    Does this mean that not all of the tune settings were programmed or originally read correctly? Thanks for your help! I attached some pics in case I am not explaining this correctly
    It is a 2012 cammed Camaro SS with 6L80e auto trans. E38 and T43 and the ECM and TCM if that is needed.
ID:	18693Click image for larger version.
    2012 SS Camaro, Cam, headers, intake, 3200 Stall 470RWHP / 440RWTQ
    Aug 2015
    Can someone please help????????? It's been months with no responses.
    Those messages are just the retry statistics displayed at the end of a read/flash process. It shows how many messages had to be retried due to glitches on the comms line. They do not indicate any particular failure or error, usually just noise on the CAN/VPW bus. When you see something like OK=795, ER=3 that just means 795 comms frames were sent/received without any errors and 3 comms frames were detected with checksum failures and were resent successfully. If any frame could not be resent successfully then the whole process stops and a real error message in the form "ERR $XXXX" would have been displayed.
    You can turn on/off that display option using here:
  1. "CRC-D failed" error message when opening tune
    By DURAtotheMAX in forum General
    Last Post: January 5th, 2015, 10:58 AM
  2. Autocal Tune Loading Issues
    By boaty3 in forum AutoCal
    Last Post: March 20th, 2012, 11:23 PM
  3. Error Message
    By RRees122 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2011, 08:29 AM
  4. Error message?
    By nathans1987 in forum Custom Operating Systems
    Last Post: September 2nd, 2009, 02:04 PM
  5. Error message
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2007, 10:48 AM
