I have a 2001 Suburban 2500, 6.0L, 4L80E. I am looking for a pin out to run the high speed e-fans I have installed. Normally, this would be the RED connector, Pin 33. But on this truck, it contains a pin out to operate the RECIRC DOOR.
Obviously, that will not give high speed fan control should the engine temps rise and the low speed fan is not enough.
Can I use an empty pin out and program it to do the high speed fan?
PCM Serv. No. 12200411
HDW NO. 09386530
Using Full EFI Live Software with V-2
Thanks in advance!
