Results 1 to 6 of 6
Thread: Aug 13, 2015: EFILive Public Pre-Release
    Default Aug 13, 2015: EFILive Public Pre-Release
    Please download and install both the V7.5 and V8 software packages.
    Both the V7.5 and V8 software were updated in this release, you must update both software packages.
    Download V7.5 Software (101 MB)
    Download V8 Software
    (64 MB) Updated Aug 15 to resolve known issue 2.
    Release Notes:
    Whats New
    IMPORTANT
    The Auto-Lock implementation for E39, E92 and E98 controllers requires that tuners and customers upgrade their AutoCal and FlashScan firmware to V2.07.86 or later. The upgrade is required to prevent *.ctz and *.coz tune files created using this pre-release (or later) from being used with older software or firmware.
    Tuners: If you update your software and/or firmware and attempt to deliver new tune files to your customers, then your customers must also update to V2.07.86 or later version or they will not be able to flash those new tune files.
    Existing tune files will continue to work normally with the new software.
    Known Issues
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the Known Issues thread.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 291
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 284
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.89 (Aug 13, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Aug 2011
    Sorry if i am posting in the wrong area, my tuner sent me a file and when i try to open it a message pops up and says This version of the file being opened is not supported by the soft wear version... Ive uninstalled and reinstalled, updated to the latest, with no luck .. Any help
    If you are trying to open the file using V7, check the V7 installed version by selecting Help->About. The V7 version must be V7.5.7.288 or later.
    If you are trying to open the file using V8, check the V8 installed version by looking at the [About] button on the main/first screen. The V8 version must be V8.2.2.281 or later.
    Aug 2011
    Thanks paul the version i have is v8 2.2.276. When i hit the update tab it says i have tue latest version
    Quote Originally Posted by Fastorange View Post
    The "Check for updates" option only indicates that a new version is available once the current pre-release version (in the first post of this thread) has been promoted to a fulll public release. That should happen in the next week or two.
    Meanwhile, download and install both the V7.5 and V8 pre-release packages listed in the first post of this thread.
    Once V8 is installed, run it and click on the [Check Firmware] button to update the firmware and configuration files on your FlashScan device.
    New update available here:
    https://forum.efilive.com/showthread...ic-Pre-Release
  1. Aug 07, 2015: EFILive Public Pre-Release
    Last Post: August 12th, 2015, 12:46 PM
  2. Known issues with Aug 07, 2015 Public Pre-Release
    Last Post: August 8th, 2015, 11:42 AM
  3. July 08, 2015: EFILive Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
  4. June 02, 2015: EFILive Public Pre-Release
    Last Post: July 8th, 2015, 05:07 PM
