Results 1 to 5 of 5
Thread: New software download, now Duty cycle is incorrect???
    Jun 2005
    Default New software download, now Duty cycle is incorrect???
    O.K., so I reboot my laptop this spring, so It is completely empty. I download the new latest software download and get it setup. I then read current tune from last fall from my pcm in the car, and save the file into my new software so I can modify it. I change the IAT/VE table correction from 1.30 to 1.00. I change my rev liter to a lower rpm, and load it back into the car. That's it!
    NOW, my injector duty cycle is at 106%, my last data log from last year, I was at 70%. What is the deal?????????? Can this effect anything? Should I care?
    I run 96 lb injectors with a injector driver at 45 psi fuel pressure. I know they are not maxed! What changed??
    Aslo, my injector flow rate(B4001) table reads from 12.1 TO 13.6 from top to bottom. The same as last year?
    WHAT COULD THIS BE?????????
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Senior Member Tydriver's Avatar
    Mar 2005
    I cant really offer alot of advice for your question.. I am interested if you have a moment or two, to explain how you get a 96# injector to work on the stock ECM.. The highest flow rate injectors can find are 60# mototronics..
    Kickass swap btw.. Anything ONLINE about your project ?
    Todd
    1993 BMW 325is <- For Sale
    2003 Silverado LS 4x4 <--- you want to autocross what?
    2005 Avalanche 5.3L LS(EFI Live tuned) <-- my gas hog running on e85 3+ years now
    2012 Subaru Outback (wife's daily)
    Jun 2005
    I use a 96 lb/ hr injector with an aftermarket injector driver wired between the injectors and the pcm. Works good. Otherwise, rc makes 75 lb/he high imp injectors that run straight off a stock pcm without the driver.
    Here is a little more about my ride.
    http://www.lateral-g.net/members/tt71chevelle/
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Jun 2005
    Anyone know an answer to my question?? What could have changed? I made another pass with a few % richer mixture and it is now at 110% duty cycle. Should only be at 70% or so.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Jul 2005
    send me some logs and your tune and i'll take a look at it, i have some boost-related spreadsheets i have been working on but haven't released yet, so this might be beneficial to both of us.
  1. Injector duty cycle above 100%
    By ls1vt209 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2008, 03:37 AM
  2. Injector Duty Cycle??
    By Ponch in forum Gen IV V8 Specific
    Last Post: September 9th, 2007, 01:30 PM
  3. TCC Duty Cycle
    By daveb in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 6th, 2006, 06:39 PM
  4. so is 138% injector duty cycle bad?
    By ace68 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 09:44 PM
